Question about Noch Construction Mini Excavator w/Figure HO NOC16762
Can't find a way to grease slew bearings or slew motor
I took off every inspection panel to find no access anywhere. Finally made a long grease tool out of a copper pipe and managed to get a bit of grease on the slew motor gears from down below through the bottom plate in the undercarriage. They were dry. Had to go "by feel", so got a bit of grease on the ring gear. But still haven't figured out how to grease the slew bearings. Are they permanently sealed? I'm thinking of drilling a hole in the retainer plate, and tapping in a grease nipple. Has anyone done this?
Washer walking all over floor and oil is at base of shock absorber on the plastic mount
If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Feb 28, 2013 | Kenmore Washing Machines
Hotpoint wd440 washer dryer. Noisy when spinning and rumbling noise when washing.. Could thus be bearing?
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Mar 12, 2012 | Hotpoint Washing Machines
How to remove the drum bearing
Thank You for using fixya
Sep 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Front panel makes a loud vibrating noise when operating
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.The noise seen on the front panle is due to vibration from the motor drive
Sep 24, 2011 | LG DLG7188 Gas Dryer
I have a front-loading LG washer model WD 80150TP. Recently it makes loud abnormal noise during the spin cycle. Could you please tell me how to fix that problem?
Jul 22, 2011 | LG Washing Machines
My dishwasher is making a grinding sound
It is so common that the machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor / pump/sprayer arm must be checked and inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the shaft and fittings must be checked. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts can solve most issues.
Finally clean the machine ,check for tips on this link:
http://www.espares.co.uk/advice/dishwashers/a/3/174/cleaning-your-dishwasher.html
Jul 21, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Treadmill stopping and grinding noise
ALWAYS UNPLUG & Remove the hood or motor cover. There's probably anywhere from 2 to 8 screws. *Now vacuum the dust from around the motor and drive mechanisms. What you can't get to with the vacumn, use a small cloth or brush. A clean motor doesn't become clogged and overheat. *After you have cleaned around the motor, look for any grease fittings, these are usually found on commercial grade units, but your's might have some also. For those of you who have never seen one, they are about the size of a pencil eraser and have a hole in the end. they are usually found on bearings. If you don't have a grease gun you can buy a small gun and grease at your local auto parts store for less than $10.00.If your unit is chain driven, clean the chain of excess dust, and apply a small amount of grease to the chain, also grease the drive chain and elevation chain as necessary. Use white lithium grease if available.Check all drive belts for wear, look for cuts and nicks, and replace as needed.
*Raise the belt and inspect the underside for wear. If it looks worn or burned you need to replace the belt.
*Wipe the deck and underside of the belt with a soft cloth, should lubricate the walking deck at least every 6 months with ilicone spray or gel or wax. Check your owners manual for what the manufacturer recommends.
Repair of Your Treadmill
Walking belt moves, but there is a loud grinding noise.
Loosen the belt and see if the noise goes away, if it does you may have a bad front roller. Sometimes you can spray the bearing in the roller with a lubricant like WD40 and this will solve the problem, but you may need to replace the roller.If the noise does not go away then the motor bearings are probably bad and you will have to replace the motor.
You can visit his treadmill website at:http://treadmills.cc/
Thanks for the rating
Good luck
Dec 22, 2010 | York Exercise & Fitness
Driver-side window non-respondent (2003 4door Chrysler Sebring)
you need to check your window switch also check the fuse box for blown fuse
Jun 29, 2009 | 2003 Chrysler Sebring
Easiest way to change drum bearings
I have changed the drum bearings on our Creda Excel 1200 V120VW. Not a simple job by any means.
The machine had to be just about totally stripped to get at the drum.
Before starting beware of sharp edges on just about any part of the machine
Remove all panels, top, rear, front facia, front panel including door, motor, powder draw
The secret is to remember to take photos or make drawings of the position of all the electrical wiring, hoses, covers and any other components you may be removing for access. Keep all you components together, it saves hunting for them later or worse still not refitting them.
Once the drum is out of the washer the drive pulley has to be removed. It is secured by means of a 30mm af nut which has also been fastened with thread locking fluid. Fortunately I have an electric ratchet gun, otherwise it would have required heat on the nut to defeat the locking fluid. The pulley is also threaded and was unscrewed with the aid of an application of WD40.
The front of the outer drum is unclipped and removed, the inner drum can then be removed by replacing the nut flush with the end of the thread, to prevent damage, and tappinng the drum out with a soft faced mallet.
This done you then have to remove the old bearings and seal. This is done be means of a drift and hammer, taking care not to bruise the area where the new bearings will be fitted.
The old seal may have to be destroyed by a sharp screwdiver or a proper seal removal tool.
When the bearings are out clean all areas with fine emery, lightly grease the bearing recesses and fit the new bearings and seal. Take care when refitting the stainless drum back into the outer drum not to turn the lip on the seal.
Now it's just a simple matter of re-assembly, make sure all parts remove are re-fitted in the correct sequence.
Another tip is not to put machine and all panels, ie; top cover and rear panels, back in place until the washer has been run and tested and inspected, to make sure there are no leaks and the machine goes through the cycles as it should.
Finally good luck!!!!
May 27, 2009 | Creda W120VW Front Load Washer
2005 Saturn Vue AWD 6 cylinder whistle
Hi all,
I currently own a 2005 saturn vue and also a 2002 saturn vue. My 2005 began making the same whistling sound around 36000 miles, I let it go and let it go. Finally it got so bad I could not deal with it any longer, I have a great mechanic and he automatically point out the carrier bareing I had it replaced and my car is very very peaceful...... :) Hope this helps.
Sep 28, 2008 | 2005 Saturn VUE
Noch Construction Mini Excavator w/Figure HO NOC16762 Logo
77 people viewed this question
Top Noch Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Noch Toy Expert? Answer questions, earn points and help others
