Samsung DVD-VR320 DVD Recorder/VCR Logo
A
Anonymous Posted on Jul 12, 2014
How can I record home VHS videos to a DVD on my Samsung DVD-VR320 DVD Recorder/VCR?
I am trying to record home VHS tapes to a DVD-R. I bought two different brands of DVD-R and each time I insert the disc I get a message saying discs are not playable nor recordable. What am I doing wrong? Do I have to buy a certain brand?
Nanny
Level 3:
Genius:
  • Samsung Master 2,351 Answers
  • Posted on Nov 22, 2019
Nanny
Samsung Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988535
Points
7262
Convert vhs to dvd via PC and software
What you need:
An analog converter device, VHS to DVD tutorial: analog converter
A PC with a DVD drive, DVD burning software (take Leawo DVD Creator as an example).
You can check on this article to see more about converting VHS to DVD.
TERRY
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 21, 2014
TERRY
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
677
Points
BE CERTAIN OF THE KIND OF DVD DISKS IT SUPPORTS. My experience is that the kind of discs while you would think would not make a difference actually do make a big difference depending on the equipment you are using. I just transferred 15 vhs tapes to DVD and realized that the machine only took a few formats luckily it was the one I was using, but not all formats may be compatible. There is a difference between DVD+R and DVD-R as an example.
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Jan 03, 2009
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
1helpful
2answers
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
2answers
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
2answers
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
2answers
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
27helpful
2answers
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
1helpful
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Not able to copy entire vhs to dvd
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
4answers
VHS to DVD recording
Yes, just turn off the tv.
Walt
4helpful
3answers
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
