Question about FUJIFILM instax mini 7 Digital Camera
What do I do if my instamax mini 8 has all the setting lights flashing and the red light on the viewfinder on?
    New Friend:
Had the same problem and discovered the motor driving the mechanism was not properly aligned. Remove the film. Take the back off the camera by removing all the screws you can see plus one under the cover where the film exits and 2 in the battery compartment. Loosen or remove the 2 screws holding the motor. The motor is located just down from the viewfinder, on top of the push button to take a picture. Turn the camera on and take a picture. The motor and gears should work, Let it run through its cycle and tighten the screws when the motor is in the proper position for smooth operation. I had to use 2 screws from the camera body to get the motor to stay in the proper position. ( i used the ones from the battery compartment)
camera now works as it should.
Posted on Mar 17, 2015
  • KWalls
    KWalls Jun 28, 2016
    Perfect. Exact same fix worked for me, thanks :-)
  • Jadene Tamura
    Jadene Tamura Aug 17, 2017
    THANK YOU! Changing the batteries and ensuring Alkaline LR6 batteries didn't work for me. Followed the directions to loosen the screws holding the motor, and now the camera works. Need Phillips No.0x50mm screwdriver.
  • 28 Answers
If all brightness indicators are flashing, that means either you have flat batteries or incorrect batteries fitted. This instax camera only work with alkaline batteries and do not use any batteries other than alkaline batteries.
Posted on Jul 31, 2014
  • Jeankee Llora Mercado
    Jeankee Llora Mercado Mar 01, 2015
    i have changed the batteries as well as the film pack but stiill it does not work.. what do i do?? thanks!!
  • lene
    lene Jul 25, 2015
    did not work for me neither!
SOURCE:
When I try to take a pic, the camera beeps and a red light flashes.
Hi. Based on your brief description of the problem I would think that the camera is failing to focus and the flashing red light in the viewfinder is the auto-focus indicator, make sure that the red auto-focus indicator is positioned in the centre of the viewfinder initially until you have experience of using it (to do this consult your camera manual) focus on a subject that has some contrast ie a red brick wall, grass or pebbles on a beach.
Apr 15, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
My instax mini 8 won't turn on.
hi there.
not sure if this link will help you out but have a look.
My instax mini 8 won turn on Google Search
Nov 17, 2017 | Cameras
Flashing red icon in viewfinder,looks like a battery symbol with a bar through it ? but camera is working fine ?
You need to change the battery that powers the internal clock and holds your settings.  The slot is on the underside of the grip.
Oct 25, 2009 | Canon XL1S Mini DV Digital Camcorder
I followed the instructions in the manual, and put new batteries in + side up. Then I continued with the rest of that step, but I did not see a flashing red LED light anywhere. I do not understand what to...
A few things to try, based on my FG's operation: - The most obvious- are your batteries good? Correct type? If they are: - When all is well the red LED metering lights will appear in the viewfinder window on the right side, in the range of shutter speed numbers. - The red LED metering lights are only activated when you press the shutter release button (halfway). The lights go out after a few seconds if the shutter button is not held down. Just tap the shutter button to reactivate them. - The shutter speed setting dial must NOT be on B (Bulb) or M90 (non-electronic Manual mode) if you want to see the red LED metering lights. The lights do not operate on these two settings because metering is irrelevant here (you'd be doing the metering, not the camera). - If you're in P (Program mode) the lens aperture must be set all the way to the smallest setting (usually f22 or f16, depending on the lens). If not, you'll only see blinking lights at the top and bottom of the shutter speed range on the right in the viewfinder. That's a reminder to set the lens to the smallest (highest numeric) aperture.
Hope these help. The FG is a great little camera.
Aug 14, 2009 | Nikon FG 35mm SLR Camera
Nikon D80. It worked fine until recently (maybe after I took pictures during whale-watching in a heavy rain and camera got wet). Now the view in the viewfinder is kind of greyish and blurry. Focus area...
Seems like your problem on greyish/blurry viewfinder is caused by the camera getting water logged. Get your cam cleaned by Nikon.
The flashing red light usually happens if you have this indicator set in the camera. This may not necessarily be an error.. just a setting that you have put in place in your menu.
Jul 10, 2009 | Nikon D40x Digital Camera
Red flashing indicator in viewfinder of my Canon XL1E
Hi . .  I downloaded the manual . . found I needed to replace the 3 volt lithium battery located on the underside of the hand grip for the zoom. Changed the battery . . . No red flashing icon in the viewfinder.
Cheers
Steve
Feb 28, 2009 | Canon XL1E Mini DV Digital Camcorder
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
1991 CANON CANOVISION E100 / E110 Red light flashing after 2 minutes, not condensation, battery well charged. No picture appears in viewfinder when red light is OK & not flashing. HELP!!!
ive gt to use it recently and it woot the canovision E100,hardly been used i went to use it and it wouldnt come on , there is a red light
Aug 19, 2008 | Canon Cameras
FUJIFILM instax mini 7 Digital Camera Logo
12,707 people viewed this question
Top FUJIFILM Cameras Experts
Falling star
Marvin
Marvin
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
