Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
I want to know the parts number of the broken part of my nikon 18-200 mm VR lens so that I can order the same from nikon, thus, i need a nikon lens manual which will show the lens parts.
    Sergeant:
  • 291 Answers
The only problem with ordering parts and doing a repair yourself is the re-assembly. Upon reassembly you will need the Nikon software and hardware to adjust and recalibrate the lens. This is not readily accessible as Nikon keeps this under lock and key for authorized service centers only.
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
Broken lens contact...Can't find replacement part
You may order the lens mount assembly or just the lens mount from here.
Nov 26, 2012 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Connect Nikon D60 to Opticron Scope
You should be able to buy an SLR adaptor from most Telescope retailers Try asking "Telescope House" if you can't see what you need (link below).
https://www.telescopehouse.com/astro-imaging.html?cat=154&p=1
Nov 26, 2017 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
I have a Nikon lens AF-S Nikkor 55-200mm 1:4-5.6G ED. The plastic part that attaches to the camera has broken and it will not attach to the camera anymore. Is this a part I can replace and where can I...
The VR lens:
http://uscamera.com/afvr55-200.htm
The non-VR lens:
http://uscamera.com/af55-200.htm
If you do the replacement yourself, you'll need a small screwdriver and a soldering iron.
Mar 09, 2011 | Nikon Cameras
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
On a new Nikon 18-55mm AF-S DX Zoom - Nikkor f/3.5-5.6 lens and a Nikon 55-200 mm AF-S DX Zoom f/4.56 lens is VR also included and standard?
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Aug 30, 2010 | Nikon Cameras
Nikkor 18-200 mm VR with loose front ring and stuck zoom barrel
Unfortunately not. If the Nikon centre think it's been dropped, then you're stuck. They may well think so due to additional wear and damage caused as the initial fault progressed; this may well resemble the damage caused when a lens is dropped. You should really have sent it for repair as soon as the fault occurred.
All you can do is to write a letter of complaint to Nikon, asking them to intervene on your behalf with their authorised repair centre. It will help if you tell them how long you've been loyal to Nikon for and what other Nikon products you own; also state that if you must buy another lens that your money will instead go to one of their competitors instead and that when you replace your camera you will think hard before purchasing from Nikon again. It also helps if you tell them that you were well aware that you would be charged for any repairs caused by misuse, such as dropping your lens, and so would not have bothered to try and claim under warranty under such circumstances as it wasn't worth the risk of having to pay a big bill just to get a broken lens returned to you. Tell them that you have not dropped the lens and so you dispute their findings, and at the very least request that the lens is returned to you without charge so that you can get the lens examined by an independent repairer.
As long as your letter is polite, factual and states your argument clearly then you maximise your chances of getting them to revise their position to give you the benefit of any doubt.
Good luck.
Mar 09, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Using a Nikon D200 with a new 18-200mm lens. When
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI,FIRST READ YOUR LENS SPECIFICATION CAREFULLY IT SAYS 18-200/3.5-5.6 IT SHOULD BE READ AS AT 18 MM IT IS F3.5,THEN AT 200 MM IT WILL BE F5.6 THATS WHY IT MOVES APERTURE FROM 3.5 TO 5.6.IT IS QUITE NORMAL. REPLY ME IF YOU ARE SATISFIED WITH MY EXPLANATION.
Jul 30, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Spare part for Nikon 18-55mm vr lens
Part # 1C999-601-2 was the number Nikon said the part was called. It was used to replace the broken bayonet mount unit as seen in this step-by-step repair:
http://www.gmtruckhq.com/artwork-design-forum/how-fix-broken-nikon-dslr-lens-mounts-3271.html#post125961
Jul 16, 2009 | Nikon Cameras
I have a Nikkon D 60 with 18-55. I want to buy a 18 -300 mm AF Zoom lens with VR.
Nikon doesn't make such a lens. As far as I know, neither does anyone else. Nikon's longest zoom range is 18-200mm. Somebody makes an 18-270mm and it is available with a Nikon mount.
Mar 30, 2009 | Nikon Cameras
Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
300 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
