Sure your remote has frozen? you can check if it is still working, by pointing it to a digital camera (camera in a phone is fine) Then press one or a few buttons on the remote and look on the mnitor screen of the camera if you see a light flickering.
If you see a light, the remote is still working.
If some buttons don't work anymore, check if somebody poured in some soda or coffee.If so, you could try cleaning it. but the best thing to do is buy a new remote. Read how manny questions are here about "universal" remote controllers and all their problems and you might decide to buy the original.
Don't forget to replace batteries so now and then.
Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
