Question about IBM ThinkPad A22p 2629 Notebook
Excelling computer memory (RAM)
My laptop only allows 512mb of RAM, which it has installed. How do I allow the computer to accept more RAM? What else do I need to upgrade? Thanks.
  • 297 Answers
If you really wanna increase the RAM level acceptance you have to upgrade *********** board. You can force more than 512mb RAM with your current system. You can use Vista in which you can connect external USB drives which can act as RAM (but only in Vista).
As of now, you can put more than 512mb RAM in your system.
Posted on Jun 29, 2009
    President:
  • 1,179 Answers
If that is all the motherboard supports then there is nothing you can do short of replacing the motherboard. Most times it would be cheaper to just buy a new laptop than to try & replace the motherboard as usually with a newer board you would need different RAM and a new cpu as well. Sorry.
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
I have a Tecra 8200 bought as used fitted with 256MB of ram. If I buy an extra 256MB which brings the total to the maximum allowed of 512MB is it likely that I will need to upgrade the bios to allow the...
This laptop came with 128mb ram, you can safely install 2 sticks of 256mb for a maximum of 512mb with no bios update.
You need pc100 sodimms.
Amazon or ebay will be the best bet as this memory is expensive now from a retailer.
I found 256mb sticks for under $10 buy it now on ebay http://cgi.ebay.co.uk/256MB-SODIMM-PC100-SDRAM-256-MB-PC-100-LAPTOP-144-Pin-/190411543153?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2c55699271
Jul 08, 2010 | Toshiba Tecra 8200 Notebook
I have a dell b110 dimension...i took the memory out to see what kind of ram it was to add more to the system. When i replaced the ram, it wont boot up. when you push the power button, it hums like it is...
Check first if the memory is loose or there are any parts that have come loose such us IDE or SATA cables, For errors you should also get warning sounds.
Sep 07, 2009 | Dell Dimension™ B110 PC Desktop
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Game not working due to less video memory
Restart your computer and your friend's computer, at the same time. Press <DEL> to enter BIOS-setup on each computer.
Do both computers show _exactly_ the same amount of RAM?
One BIOS-setting may allow you to "dedicate" some of the RAM to be used for "video-memory". Do both computers show the same amount of "dedicated" RAM?
Jun 01, 2009 | Lenovo 3000 V100 Notebook
Thinkpad T20 won't accept memory upgrade
according to ibm
you are allowed only pc100 memory with a maximum of 512mb.
when handling memory make sure you are grounded before touching any memory chips.
try getting another set of 256mb chips and grounding yourself before installing them.
Mark
May 15, 2009 | IBM ThinkPad T20 2647 Notebook
Memory upgrade on presario 4403us desktop
Hi yes thats correct you can have only 512mb RAM. This is due to your motherboard limitations or bios limitations. The only way is to change the motherboard this will allow you to also have latest usb 2 support. Just buy a motherboardboard thats compatible with your processor and existing memory.
Mar 14, 2009 | Compaq Computers & Internet
Compaq M700 Ram Upgrade the second
i can find no spec on this but,if your notebook can take upt 576MB of memory, i would expect 2 x 256MB to be the max, as installing 1 x 512MB would be doubling the capacity allowed by one module slot.
Oct 01, 2007 | Compaq Armada M700 Notebook
IBM ThinkPad A22p 2629 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
