Question about Dell Inspiron 700M Notebook
Dell Inspiron 700m blank screen or won't boot
When I turn on my laptop, screen goes blank after 1 or 2 sec but power is on, wifi indicator is on, i don't have a battery, i've been using ac for the last 4 years and no problems then this happens, but when i try turning it off & on again for 20 times sudeenly it works and i could use it for as long as i want, but when i shut it down and then use it again in a couple of hours, same thing happens... im afraid it might not work next time....please help thanks in advance!
  • friendstersu Jul 07, 2009
    thanks for the replies, external monitor seems to be working so its not the motherboard or video card, i already changed the inverter, nothing happened, i did a checkdsk, all ok...i checked the little switch that turns the laptop to standby when lid is close, its clean and working fine..so i figured i need to changed the backlight bulb but its not easy even for a experienced technician and they would probably charge a lot, so im just going to buy a new lcd screen for a $115on ebay and hopefully it will fix the problem...thanks
  • friendstersu Jul 19, 2009
    Hello, thanks for the replies..i found the solution! i did a checkdsk, external monitor was working so it wasnt the motherboard or video card. i also changed the inverter which i bought for $9, shipping was included. but when it still didn't work, i tried cleaning the little lid switch and nothings wrong with it. so i bought a new lcd screen on ebay and that solved my problem, by replacing the lcd! my lcd was au optronics B121EW02 v.0 but seller sent a B121EW03 v.7 and it still worked.. i hope this helps to those who has the same problem...
    Scholar:
  • 52 Answers
The problem you are facing sounds like either a video board problem, which I believe the 700 is hard solered onto the motherboard or an inverter board. The best way to test this is to hook up an external monitor to your laptop and see if the problem persists. If the problem does not appear on an external monitor, then the problem is most likely the inverter board in your laptop. If you are still having the problem with an external monitor, then your video card is at fault. The video card on this series I believe is hard soldered to the motherboard and cannot be replaced without changing out the motherboard. If the problem goes away with an external monitor then you just have to replace the inverter board on your laptop which you can pickup on eBay for around 30.00 + shipping.
Posted on Jun 29, 2009
  • 255 Answers
1.format your system
2.reinstall your operating system
3.this problem occurs due to software corruption or harddisk corruption
Dell inspiron 700m break the password
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-700m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 01, 2011 | Dell Inspiron 700M Notebook
How can I use the built in wifi on a dell inspiron 700 m
Fn+F2 whould turn wifi on and off (toggle), give it a couple seconds after each press.
Here are the latest dell official drivers for the intel wifi:
http://support.dell.com/support/downloads/type.aspx?c=ca&l=en&s=gen&SystemID=INS_PNT_PM_700M&os=WW1&osl=en&deviceid=7039&libid=5
Sep 08, 2010 | Dell Inspiron 700M Notebook
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Sep 28, 2009 | Dell Inspiron 700M Notebook
Dell 700m wont boot with new hdd
Hi
Need to know how far it boots, eg past cmos screen, ??Win screen
Also some laptops will only accept hard drives up to certain sizes. Check in the Bios as to whether that size drive is actually supported.
Aug 12, 2009 | Dell Inspiron 700M Notebook
I have a dell inspiron 700m laptop. My son tried
Boot from your xp disk and install xp.
That will overwrite ME.
You have to set the boot sequence in the BIOS as follows> 1.CD-ROM(DVD)
2. HDD
Mar 05, 2009 | IBM ThinkPad R31 2656 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Laptop does not Boot - Screen Blank -- Fan On
Sounds like your hard drive may be going out, do a check disc.
Jul 10, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700M Notebook Logo
1,245 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
