I recently moved into a house with this washer/dryer set, so I have no manuals. I have noticed in the last week or so, water collecting in the drawer where the fabric softner and bleach would go. Any ideas why and how to solve? I have cleaned the drawer out once, but it just came back.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Bit the bullet and stripped out the covers from the unit so as to observe where the leak was coming from. Ran m/c on a basic quick wash (be careful, exposed live electrical terminals!!!) and noticed that water came from the detergent drawer for a second or two.
Stripped out detergent drawer housing and found that the large discharge pipe underneath was very blocked with black/white residue. Presume that this had been dislodged from the walls of the pipework during the house move.Removed residue and reassembled unit & ran, OK.
Saved myself £100 call out. Give Miele their due though, the documentation suggests that if you habitually wash at a low temperature, which we do, you should occasionally run a 95degree wash. My wife was very surprised when I asked her if she did this.
The detergent/softner dispenser is located above the detergent drawer.
A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer.
By opening upper machine's cover you will have an access to the dispenser.
Disconnect the power cable from the machine before moving to next test !!!!
Look first that they are not any disconnected wires.
Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit).
In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced.
Good luck !!
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve.
2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
The detergent dispenser is located above the detergent drawer.
Good luck !!
I guess I could have said it was the Kenmore Ecocycle washer/dryer set...
