Question about Sub-Zero Bottom Freezer Refrigerator
Ice Cubes are wet, meat is frozen but ice cream is soft.
  • 33 Answers
SOURCE: ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Posted on Nov 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
OK send me the model number as found in photo below. You may have a circulation problem that I will be able to look over closer when I have model number. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 26, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Frigidaire FPCE-21TF model standard top freezer.
If the compressor (motor - black thing at back) is running all the time, then your fridge may be running out of refrigerant - and is dying slowly.
However - if it turns on and off happily, then it could be the sensor in the freezer needs replacing. You can buy these yourself and is just a plug-in , and a cheap fix for you.
If this doesn't solve the problem, it will be the control board is out of tolerance. You may be able to tweak it - or could be preset.
Try a new sensor first. Sometimes corrosion on the connectors is enough to cause problems. - take out and replace - or swap with the refrigerator sensor.
Posted on Aug 04, 2009
  • 31 Answers
SOURCE: ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Posted on Aug 07, 2009
  • 146 Answers
SOURCE: Ice Cream and frozen waffles won't freeze.
LOL ! SO in other words in plain english your repair man told you needed a brand new refrigerator - Ok from your description here we can rule out low refrigerant or compressor problems, defrost timer and controlboard issues. I too have waffles and they DO get frozen although not as hard as ice - the less water molecules they have the less they are frozen hard. but nonetheless, my waffles are NOT soft, neither is ice cream
What I would ike you to do is put one of those refrigerator/freezer type thermostats, you can get those round ones, place it in your freezer leave it there 24 hours and look again - Optimal freezer temps is 0F once compression cycles off - if you areusing the extra cold setting, -10F - For refrigerator don't go over 40F - optimal temp of 36-38F.
Another method you can place a bowl of water and use one of those probes and measure the temp of the water in your fridge. If your temps are within safety levels do not worry - your ice is frozen and your frozen food is frozen - Some ice cream tend to be softer, especially the extra creamy type. If your refrigerator has a dial to adjust temps, raise it slightly and wait 24 hours and check your temps again you might need to bump down the temps a bit - if you have a control panel and 2 settings they are usually COLD or COLDER, set it to COLDER and check again - in the COLDER setting your compressor will shut down once your freezer hits -10F that should be quite enough to have even your waffles and extra creamy icecream frozen - if some of the liquids in your refrigerator is too cold or freezes, set it back to COLD or re-adjust the dial. Once you determined that your freezer AND refrigerator are within SAFETY levels as per the food safety guidelines and using the proper methods of testing, then you have nothing to worry about. Make sure your fridge and freezer are not leaking cold air by checking your door gaskets using the famous dollar bill technique by closing the door on the dollar bill and trying to pull it out - if there is no resistence and can easily come out, you have a gasket leak - check in different places on the gasket. As long as you can determine that your freezer and fridge temps are SAFE don't spend a dime ! If your temps are NOT in the safe range you probably have leaky gaskets - if the compressor seems to run all the time, you probably have dirty condenser coils that need to be vacuumed cleaned or dusted off using a condenser brush.
Posted on Aug 17, 2009
I need a free manuel plus recipes for my deni 5500 soft serve ice cream maker
On the web:
Search Results
    DENI 5530 INSTRUCTIONS MANUAL Pdf Download.
    www.manualslib.com > ... > Deni Manuals > Frozen Dessert Maker > 5530
    Deni - Keystone Manufacturing Co, Inc. Ice Cream Maker Instruction Manual. ...Freezing the Speedee Freeze ® Canister Deni Soft Serve Ice Cream Maker. ... placing in the Scoop Factory, and freezing canister is as close to -20°F as possible.
Oct 02, 2015 | Deni 3400 550w Meat/food Grinder
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Ice cream in freezer of our side by side refrigerator is soft
Try cleaning the condenser coil. It will be under or on the back of your frig. Use a vacuum cleaner attachment. Good luck
Sep 08, 2009 | GE GTS22KBP Top Freezer Refrigerator
Ice cream soft
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Some items in freezer are not frozen: bread, cool whip, etc. Meat and veggies ARE frozen. any idea?
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
May 22, 2009 | Refrigerators
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Ice maker not making ice
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Sub-Zero Bottom Freezer Refrigerator Logo
79 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
