Question about Sanyo DS25390 TV
Sanyo DS19390 buzzing sound
SOURCE:
Sanyo flat panel tv has buzz overlaying sound
two things, does it do this when a dvd is played using a rear audio/video input: and is it there if sound is all the way off or muted?
Dec 19, 2012 | Sanyo Televison & Video
Does the Sanyo DS19390 have an audio jack??
yes check at the back of your tv you will see their the small holes colored yellow.white and red theirs a printing av in or out insert it their.
Oct 19, 2010 | Sanyo AVM-2758S 27" TV
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Jun 06, 2010 | Sanyo AVM-1909S TV
I have a older sanyo ds19390 tv that is buzzing inside, not thru speakers please help
In older tvs the buzzing sound usualy comes from the HT lead plugged into the tube .open the back and switch the tv on (do not touch anyware near the set the HT lead carries avery high voltage even when the set is off)if u do see arching then u need to clean around the rubber of the ht lead )u can leave the set unplugged for a couple of days to allow the tube to discharge before attempting to clean around it.
Apr 13, 2010 | Televison & Video
Component R601 (a relay) is chattering/buzzing. Sometimes stops after set has warmed. What is the function of this relay? Can I wire around it? The set is Sanyo DS19390.
The relay is used for degaussing the screen(demagnetizing). Don't bypass that or you will have some problem. That relay is suppose to come on only for a few seconds then turn off. Relay coils run on smooth DC. If the supply to the coil has a fluctuating voltage it will do that. The cause of this is usually a bad filter capacitor, or a leaking semiconductor, either a diode or a transistor. Trace the circuit to see what drives the coil. Check any filtering capacitor connectec in parallel, and also perform a "go/no go' test on any semiconductor that drive that coil. You tube has video instruction on "go/ no go" test. It is better explained with a video.
Jul 02, 2009 | Televison & Video
TV buzzing
may be a problem with power supply unit.
Nov 14, 2008 | Sanyo DP42746 42 in. Plasma Television
How can you reset a model ds19390 Sanyo tv back to factory settings without original remote? It is an older analog set.
Hi again,
Please see your latest post.
Just a start, do postback how things turned up orshould you need additional information. Good luck and Thank you forusing FixYa.
Additionally,pls be informed that you would be lowering my ranking/rating if yougive me a rating if less than a FixYa. Doing so would prevent my beingable to provide further assistance.
Nov 10, 2008 | Sanyo Televison & Video
Television problems
Have the speakers ever been played loudly? They may have been pushed passed their capacity, in which case, it may be time for a new tv.
Dec 16, 2007 | Televison & Video
Sanyo television
That set is probably not ready for the dump yet. The buzzing sound could be the power supply going into shutdown because of a shorted secondary supply, usually a shorted horizontal output. A good tech should be able to fix that at a reasonable price.
Jun 28, 2007 | Sanyo DS32224 TV
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
