Question about Hobart N50 Stand Mixer
N50 shifter pin buzzes in 2nd and 3rd gears
My N50 (ML- 16472) buzzes in 2nd and 3rd gear. If, while it's running, I put just a little clockwise pressure on the shifter handle, the noise completely goes away. I'm pretty sure the noise is the shifter pin rattling against the cam-plate. I just finished reassembling and re-grease-packing my N50 (in part to alleviate this problem) and this did not seem to work. No setting of the screw(s) on the bottom of the planetary seem to make any difference. I cracked open the gear housing again to see if I could see any obvious problems. One thing I noticed was that, no matter where I moved the shifter pin, the sharp rectangular stopper-pin on the far side of the tumbler-yoke never came in contact with the tumbler-yoke-stop. This was true even if the yoke-stop was fully extended by tighening the external set screw that governs the yoke-stop's travel.
Could the entire yoke have been bent? I wonder because shifting into 3rd gear is a little stiff, and the shifter pin rubs hard getting around the final corner of the "W" in the cam-plate.
The noise is not terrible. Is it detrimental to the longevity of the mixer to just let it be?
-j-davis
  • j-davis Jun 29, 2009
    I'm sorry. The way you answered the question, it appears that you think this is car. This is a Hobart N50 Mixer -- for dough. It does not travel uproad or on bumpy roads.
  • 378 Answers
Probably the entire yoke have been bent, did you check the gear shaft ? if the shaft bushing is loose this will also cause to buzzes.
Posted on Jun 29, 2009
  • 615 Answers
I think the entire yoke have been bent.Because of this the third gear is little stiff compare to 2nd and 3 rd gear. so shifter pin rubs hard getting around cam plate..some time noise is very low but in some times mainly in rough road and up road it gives hard noise.Solution is replace the tumbler yoke or entire yolk stip.
  • Chandrashekhar N.G
    Chandrashekhar N.G Jun 29, 2009
    First, as an N-50 gets old, the grease tends to harden and no adjustment will help. Repacking the grease is not incredibly difficult for the average mechanic.
    The adjustment -- Look on the bottom side of the planetary towards the column. The is a set screw. It should actually be a set screw on top of a set screw.
    Remove the first set screw. Back out the second screw one to two turns. Run the mixer in 1st gear. While it is running adjust the screw to reduce the noise. (Do not force the screw inward, it doesn't really bottom out.) Repeat in 3rd gear. Test in all gears, and repeat the adjust for the best results.
    Something else you can look at --- unplug the unit, remove the shifter switch plate, (note the gear selected), check the two screws at the top of the opening in the transmission section.
    Also, with a good set of eyes and a flashlight, you can get a peek at the grease.
    2.If it is not
    CE is the marking that shows its european conformant. I think the difference is mostly in terms of the no volt interlock switch. This means the KA style N50 bowl won't work with the CE models - too low.
    When you put the plate back on, hold the shifter in the "selected" gear. Good luck, let me know if you need more specific help.
    View 1
    View 2
    http://www.hobartlink.com/extranet/extra...$File/F43056%20Rev%20A_LK.pdf
    http://www.fixya.com/support/t552263-new...
Hobart N50 noises
The frequency is the same in all gears.
disconnect the power and invert the mixer and remove the planetary after driving out the taper pin, then you can access the transmission. It may be a rotor shaft bearing in the motor or no grease on the worm gears.
Nice touch with the video.
If you need parts:
Jan 04, 2014 | Hobart N50 Stand Mixer
Locks up in 3rd gear after rebuild
Jeff your almost there....it must be the shifter into third....it must not slide fully into third....check for wear marks on the worm gear....and try running it without the protective cover on to see how it changes from 1st, into 2nd, then third...that mechanisim if not engaging totally in third.
Dec 03, 2013 | Hobart A200 Stand Mixer
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
My older model Hobart n50 mixer stopped working. The motor is running but three teeth on the fiber gear were broken off from the main gear in the transmission. While removing some of the grease, I found...
The best solution I can give you is to become a member at the Hobart Corp. website and use there schematics to find where the pin goes. It is free to use the parts catologues have a parts blowup.
Follow the link below:
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FsalesZ2Fredirect.aspx&reason=2&formdir=2
Thank you for using FixYa, I hope this helps.
Jan 19, 2011 | Hobart N50 Stand Mixer
Worm gear hobart slicer
What is the model number?
Apr 06, 2009 | Hobart N50 Stand Mixer
Hobart A-200DT mixer lugs out
Can you be more specific?Does 1st gear run? are you overloading it?
Mar 18, 2009 | Hobart A200 Stand Mixer
N-50 rebuild help
Remove the shiny drip ring on the planetary, use a small screwdriver and gently pry it off. Remove the "Tapered pin" that holds the planetary on the shaft, gently use a punch and a hammer to do this. This pin can only be tapped out in one direction. Pull downward on the planetary assembly until it comes free. Examine the small gear and bearing for excessive wear, examine the ring gear that remains in the mixer body for wear. Clean and re-grease these gears if they look OK. These gears are in operation in any gear and as such, receive the most wear. When re-assembling the planetary re-install the tapered pin the way it came out. The previous solution will address the transmission gearing. Replace parts as necessary. Good luck. Please rate this solution if it helps you. ricardok45
Oct 10, 2008 | Hobart N50 Stand Mixer
Hobart N-50 mixer clangs on 1st and 2nd speed
Jun 03, 2008 | Hobart N50 Stand Mixer
New (old) N50 ML-4749
You should be able to purchase the manual. I know that Hobart abandoned that policy a few years back -- unless they re-instated it. Call Mother Hobart and ask. 937-332-3000
There is a few tricks to these units, it would be tough to convey here. But here goes...
Remove back cover. Loosen 6 or 7 screws around outside of motor windings. Thump the nose of the mixer downward to break the seal. Watch for spacer washers where shafts go into motor case. Remove spring. Remove idler. Remove shifting guide. Remove gear assy. Leave beveled gears in place if possible. Clean. Use Darina II grease. (20 oz) Clean and permatex "seal". Tighten mounting bolts. Adjust set screw at back of planetary. (Double set screw. The first one is to lock the adjustment.) Test in 1st and then 3rd while turning the set screw. You just make it quiet for a proper adjustment.
Good luck -- Mike
Apr 28, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
187 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
