Grill works, but both ovens do not work.
Looking at the circuit diagram, it appears that there is a problem with the programmer. There is a contact that operates in it to provide power to both top and bottom ovens. The feed for the grill is prior to this contact, which explains why this is still working. Is the clock/programmmer set correctly? In some ovens, if the clock is not set then the ovens do not work. You should be able to hear the realy operating when the clock is set. If you need a copy of the handbook then if you supply an email address, I will send you a copy.
