Question about Sony Cyber-Shot DSC-W5 Digital Camera
My battery lasts for about a dozen snaps only
After taking abt 10-12 snaps the battery icon shows half empty and then it dies off...i had purchased new batteries thinking that it might be a problem with old ones but the problem still exists...i keep my batteries on charge the whole day but in vain
  • 285 Answers
What battery type and size/capacity are you using?
Posted on Jun 29, 2009
  • Dean
    Dean Jul 15, 2009
    Basically you need to be using NiMH rechargeable batteries. If you are using alkaline or other low power batteries, the camera will consume these extremely rapidly. Get yourself a set of NiMH batteries along with a charger and you should find the batteries last a lot longer!
Have tried to reset. Did not work. Have tried several outlets. Did not work. How do I chcek the battery.
It would help knowing what operating system is I.e. Windows 7 or 8.can you get into safe mode by repeatedly tapping f8 this should give you drop down menu for last known good configuration.choose this to see if the laptop returns you to a desktop.the battery can be checked by leaving the power supply in until you get to the open screen desktop then remove power supply and check the icon for battery bottom right.if you hover the cursor over the icon it will give battery life in percentage.batteries eventually fail mainly because people do not charge them properly.you need to run it flat occasionally and do a full recharge.once it reaches 100% take the power supply off and run it down to 20% and charge back to 80 % half a dozen times in between full charges?also in control panel there is an icon for battery whereby you can force the battery to discharge so you can re educate the full charge memory,this usually increases the stamina of a failing battery.
Apr 12, 2015 | Computers & Internet
Tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | Computers & Internet
How long does charge last, want to charge before giving as a gift
charge to at least 50%. (For storage purposes, so that the battery won't get messed up).
You can tell this by checking the battery indicator (bars, icon or percentage) periodically. If it shows 50% or an icon that shows a battery half-full.
sorry if this was confusing, as I am tired.
Dec 04, 2013 | Cameras
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Cameras
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Battery won't hold a charge
Buying recharable batteries will not solve the problem of the battery draining quickly but will help save $ by not having to purchase so many disposable batteries. Check your user guide to see what kind of batteries your camera will accept. Lithium ion rechargeable is the best if compatible. Lithium ion disposible (CRV3) will last a long time as a secondary choice if compatible. Some cameras drain batteries more quickly than others. Just a tip to help reduce the drain: don't use your LCD screen when unnecessary (such as scrolling through several of your pics in-between snapping pics).
Nov 25, 2008 | Olympus FE-230 Digital Camera
Battery pack
I don't know if this will work but it worked for my PowerShot A300.
Take a pencil eraser and clean the battery connections inside your camera. Just be sure not to let any eraser flakes inside the camera.
The Canon rep indicated it would work for the A300 ... Not sure why it wouldn't work with yours as well.
Good luck.
Aug 29, 2008 | Canon PowerShot SD870 IS Digital Camera
Battery Empty
the little icon battery looks empty on the lcd screen? I would not worry about especially if your camera is taking flash pictures and lasting a good while....for my battery indicator on my two different cameras looks half charged and they high amp 2700ma. maybe its going over the mark. try putting in common batteries like duracell and see if it dont return to full indication charge.
Aug 31, 2007 | Olympus Camedia C-725 Digital Camera
Battery Problems Canon eos 10D
My battery works for weeks. It might be a problem with the camera. Could it be the contact points in the camera?
Nov 28, 2006 | Canon EOS-10D Digital Camera
Sony Cyber-Shot DSC-W5 Digital Camera Logo
201 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
