Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
MY TV WONT STAY ON WIDE MODE. wHEN THE ADVERTS COME ON IT CHANGES BACK TO HALF SIZE. I HAVE A NEW SONY BRAVIA
This is actually due to the signal format being sent down from the transmitters/broadcaster. They by defauly output 4:3 which your tuner in your TV interprets and rejigs it into 16:9. Te adverts as they come on are seen by the tuner in your tv as a change in aspect ratio, and therefore your TV is trying to best display these. However, if you go to your screen settings, you can change the screen auto format to your choice and this chould ensure that the picture always gets set to your choice. If set on default, it will vary between 'wide' and 'smart'.
Posted on Dec 16, 2009
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The picture on my sony bravia 52 in is huge and I cant seem to be able to fix it. On the picture size it is set at wide mode and normal is not highlighted to be able to change it
Try pressing HOME, Then go to SETTINGS From the list, select SCREEN
There are now several options that may be causing the picture to zoom. Try adjusting each setting in the following order, checking if the problem has solved after each change.
Set: DISPLAY AREA to NORMAL WIDE MODE to NORMAL AUTO WIDE to OFF 4:3 DEFAULT to NORMAL
If you are still having problems, you may need to speak to Sony about having the TV serviced as an internal circuit may be broken - if this is the case it may be covered by the warranty.
I hope this helps - if you require more info, here is a link to the Manual for your tv http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/0451c422be8f7211d50375af6ace50aef8fb6504.pdf
May 04, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have connected my laptop to my sony 40ex403 bravia. The screen is centred on the tv screen. How do get it to full screen size?
Hello.
On your TV remote control there is button "Picture mode" or similar name. You can change image to "zoom" or "wide" by using it. Sometimes if in "zoom" mode it still not fill whole screen - you have to change display settings in you notebook for external display.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a 52 inch SONY Bravia that has been stuck in zoom mode since last night. iI am unable to see the writing and/or tops of heads on top of screen. any help available?
Press the "WIDE" button on the TV remote a few times to change the TV wide mode settings until you get it to "FULL". If that does not fix it, look on your Cable box remote for an "Aspect" or "Format" button and press it a few times. I hope this helps.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
406 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
