Question about Whirlpool LER8648P Electric Dryer
Model #ler8648pw1-dryer runs but does not heat and will not shut off
    President:
  • 1,865 Answers
Sounds like the timer has failed
Posted on Jun 29, 2009
Electretic dryer shut off arter two minutes
Heating element must be shorted to frame causin overheat and shut down. You gonna need to take it apart and see where the problem is. Post a make and model number for a better answer. Lots of dryer repair videos on youtube. I have manuals for repair on my youtube channel just google: dan webster dryer.
Feb 27, 2014 | Dryers
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Hello, My gas dryer FRIGIDAIRE with model
check exhaust ducts and inside bad of machine for lint blockage over heat shuts down heat if not igniter or gas valve failure likely
Jul 06, 2009 | Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Whirlpool LER8648P Electric Dryer Logo
227 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
