The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/I hope this helps, if so please rate my solution.
BuddyMc
