Question about Logitech Audio Players & Recorders
Logitech z-5450 control unit shuts down on it own and reverts to factory defaults? Doesn't matter if on for 1 hour or for 6+ hours. Annoying when watching something and then all of a sudden No Sound. I have Direct tv HD/DVR, Sony PS2 and computer connected (Direct tv-coax input. PS2-optical 1 input. computer-6ch direct input). It will stay on for ever with no input signal. Does this possibly mean an over heating problem? Though I would think it would just shut itself down and not reset all settings? But I don't know if that is the way it should work, since I bought this used and no info on the logitechs site (well, virtually no info there. nothing on this problem for sure). Is this normal or is there something I can do to prevent this from happening, possibly a fix?
2 Suggested Answers
SOURCE: Logitech Z-5500 Work Just with Optical And Coaxial cable
i think its something to do with your operating system, since you have said its works for few min.
Posted on Feb 21, 2009
Unit shuts off shortly after I power up
There is an internal disconnect after the unit heats up due to an open resistor, capacitor, diode, or small fracture on the circuit board. The cost of repair is greater than the replacement cost, therefore if it is under warranty get a new one, or pay to have the current device repaired by a technciain.
Jan 16, 2014 | Logitech Z-5450 Computer Speakers
How to set time on iPod dock model S00067
The manual can be downloaded from the Logitech Website. The link at the bottom of this post is where the manual can be found for your unit or click on this link (you need Adobe Reader to view it which can be downloaded for free)
http://logitech-en-emea.custhelp.com/ci/fattach/get/502116//session/L2F2LzEvc2lkL21ReUpSR0Fr
Logitech Pure-Fi express Plus page:
http://logitech-en-emea.custhelp.com/app/answers/detail/a_id/10300/section/troubleshoot/crid/439/lt_product_id/4781/tabs/1,3,2,5/cl/gb,en/kw/
To set the clock as per above manual:
1. Press and hold the clock set button (the hour will blink)
2. Use control knob to adjust time hours (PM will indicate if not then AM is default)
3. Press clock set button once which will confirm hours and advance to minutes setting (the minutes will blink)
4. Use control knob to adjust minutes
5. Press clock set button once to confirm time set
6. Clock settings now complete
Oct 24, 2013 | Apple iPod touch
Updates not configured. reverting changes... whenever i shut down r switch on it is coming like "configuring 1 of3 updates...." after a some time updates are not configured well.reverting changes" . am...
indicates a register problem
run the recovery disk
or
in the search box under the programs list type in CHKDSK and enter
This program runs the entire library and fixes and rectifies any problems in software , file and folders --takes several hours
Dec 06, 2017 | Computers & Internet
How to set Clock for S00067
Aug 04, 2011 | Logitech Pure-Fi Express Portable Speaker...
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Need remote control code for hyundai Q321 TV
Hi Friend,
If u have not changed the default then u can use the below mentioned code as follows,
The code for the Q321 for the remote is 7788 If u have changed the default and u cant find it then u can do factory default with the help below process, Removing the batteries for a few hours will reset it back to factory setting? Check and revert back,kindly dont forget to rate this, Thanks for using Fixya Regards, Ayyasam
Jul 02, 2009 | Televison & Video
Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
May 30, 2009 | Logitech Z-5450 Computer Speakers
Resetting lamp timer
Try the following:
you need to enter factory Menu.
You do so by doing the following:
1).Start the projector.
2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
Let me know if this solves your problem.
ry this:
Jun 09, 2008 | LG RD-JT30 Multimedia Projector
Reset lamp timer
Sep 03, 2007 | LG RD-JT30 Multimedia Projector
373 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
