Question about Brother Office Equipment & Supplies
Phone line is working but can't get a dial tone. Tryed the hook button, no tone.Unable to turn fax off with pushing the button.Only way to turn it off, is to unplug it.How do I reset the machine?
  • 313 Answers
The first thing you should check is the socket you have put the fax line into at the back there is usually two sockets one says line and one tel..make sure you have it in teh line socket as this is for the fax line in... teh tel socket is usually to connect a phone handset to.. if this works let me know.. good luck A
Posted on Jun 29, 2009
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
FAX function stopped working
honestly, it sounds like you have the phone cord and the fax jack swapped backwards, make sure you have the fax line plugged into the correct jack on the machine. 1 is for the handheld phone and the other is for the telephone line... give this a shot...
Mar 10, 2008 | Brother MFC-7220 All-In-One Laser Printer
Phone
WHat model is the fax machine? Also check to make sure that the phone line and the fax line are not 2 different phone jacks. Also if the phoneline and fax line are on the same jack, make sure to program the fax number into the fax machine. Also, double check if the fax machine has an in and out phone jack that it is in the in jack.
Feb 21, 2008 | Sharp UX 355L Plain Paper Thermal transfer...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
83 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
