Question about Creative Labs Creative Technology Zen MP3 Player
Hi again. I have another problem you supposed to press the left button below too turn on the speaker but i press the button on and is not working and they send me to another thing i dont know that if is me mp4 or another razon and i wan to know if i can do something to repair or maked work
  • 820 Answers
The lx model does NOT have 2 options:
1. no speaker: so the earphones should be plugged in to get sound
2. no fm tuner: no radio function
for the rest the lx model should give all the functions like the regular one
Posted on Jun 30, 2009
Hooking up a intellitrox tach on motorcycle but instructions only show for 4 6 8 cyls
Most Intellitrox Tachs will work on 1,2,4,6,8,10,and 12 cylinder engines. The mini-tach (MS9002) only works on 4,6 and 8 cylinders.
So if you have the mini-tach and do not have 4 or 6 or 8 cylinders, you should use a different tach. If you have a different unit, or have 4 cylinders, then see the second step below from their installation guide.
To change settings: (a light tap on the left button will engage the menu system: the right button will then be used to adjust each specific setting.) 1. Leftbuttonpressed:
Set # of digits in RPM display, using right button, display shows: (hundreds) 9900, (tens) 9990, and (ones) 9999.
2. Leftbuttonpressedagain:Set # of cylinders using right button, display shows: 01_C 02_C 04_C 06_C 08_C 10_C 12_C
3-A. Left button pressed again:
Set first digit on max RPM on gauge bar display (in thousands) using right button, display shows: 10__B to 99__B
3-B. Left button pressed again:
Set second digit max RPM on gauge bar display (in hundreds) using right button, display shows: 10__B to 99__B
4-A. Left button pressed again:Set RPM first digit shift light threshold (in thousands) using right button, display shows: 10_S to
90_S
4-B. Left button pressed again:Set RPM second digit shift light threshold (in hundreds) using right button, display shows: 19_S
to 99_S
5-A. Left button pressed again:Set first digit output switch RPM threshold (in thousands) using right button, display shows: 10_S
to 90_o
5-B. Left button pressed again:
Set second digit output switch RPN threshold (in hundreds) using right button, display shows: 19_S to 99_o
6. Left button pressed againWill return to normal mode, or if there is no new information to access, after 8 seconds, the
gauge automatically returns to normal mode.
When you have finished programming the settings, turn off the ignition to retain them in the gauge's memory. Next time you turn on the ignition, your new settings will be the default.
Nov 05, 2017 | Motorcycles
Tip
HP All-In-One can send but cannot receive fax or can receive but cannot send
One of the most common problems with HP All-in-One Printers is that they can send out fax but cannot receive or they can receive fax but cannot send. Now, what more could possibly be the problem if you are sure that your connection cables are correct and properly setup? Well, most people don't know that this is more often than not, caused by the ECM feature of the fax.
ECM or Error Correction Mode is used by fax machines during transmission. This feature is used to eliminate transmission problems especially when you have a "dirty" or noisy telephone line or a very poor signal can result to fax failures. ECM mode, when is turned ON is supposed to check for errors and glitches and is supposed to make the reception or transmission of faxes come out successfully.
However, for some reasons, the ECM mode is not supposed to be performing well with its feature. Especially if the user has a problem with the telephone line, the more that they cannot receive or transmit a fax. It is then recommended that your HP All-In-One printer's ECM fax settings be turned OFF. To do this, follow the steps below:
1. On your printers front control panel, press the button with the wrench symbol; this is the Setup button.
2. Press the right > or left < arrow until you see Advanced Fax Setup then press OK.
3. Press the right > or left < arrow until you see Error Correction Mode; again press OK.
4. Press the right > or left < arrow until to select Error Correction Mode OFF. Press OK to confirm.
That's it! You may now try to send out a fax or ask a friend to send you one.
on Mar 07, 2010 | Office Equipment & Supplies
Tip
on Dec 02, 2009 | Office Equipment & Supplies
How do I turn do not disturb off
With the Comdial Impact 8012S and a few other models, the DND feature is toggled on and off through the menu system as follows:
1) Select Options (the right-most button below the LCD screen)
2) Press Next (use that right button again) until DND appears as the current option.
3) Select DND (by pressing the left-most button).
4) Select OFF (by pressing the middle button).
5) Select Exit (the right-most button, again)
6) Press Speaker to end the programming mode. The speaker button is on the body of the phone towards the right and bottom of the keypad. The exact position depends on the model.
I hope this works for your model as well. If it doesn't, please add a comment with the model of your phone.
Jun 23, 2015 | Comdial Lands Phones
Does this phone have speaker phone, and if so how do i turn it on?
Yes, there is a speaker option. Holding the phone in your hand look down to the lowest row of buttons - below the * 0 # buttons. There are four buttons: from left to right they are SPEAKER; PAUSE/REDIAL; REMOVE/MUTE; and, INT (INTERCOM.) Pressing the left/SPEAKER button one time turns on this feature. Pressing this button turns OFF this feature. Hope this was helpful.
May 11, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
I bought this recover and so far everything works but for some reason I cant get any surround sound from the recover running hdmi from blue ray player on the display it shows sw, LF, RF that's all I can...
hi,
you reseiver is now in stereo mod that's why there is no surround and center. its some thing related to to the setting in the receiver or in the blue ray.
Settings in blue ray player
First of all check the audio settings in your blue ray players audio setting.
You didn't mentioned the brand of your blue ray player. Anyway go to its setup and set the audio output priority as HDMI. also turn OFF the DRC if its a sony blue ray player. Also check the down mixing setting make it satandard
Settings in receiver.
First of all check the surround settings.
Play a blue ray disk and press the STANDARD button o the receiver's remote and select STANDARD mode.
If you didn't get the surround channels follow the below procedure
Now go to the setup of your receiver.
1. Using the down arrow go to the Advanced play back and press enter.
2. In the Advanced playback menu select auto surround mode and press enter
3. Select it ON using right arrow or left arrow. and press enter
4. Exit the setup and check is every thing working fine.
If dosn't work
Again go to the setup of the receiver
1. Using down arrow select Speaker setup and press enter
2. In the speaker setup menu select speaker configuration and press enter
3. Check the status of all the speaker, if any speaker is in NONE position , make it LARGE or SMALL according to the speaker you are using.
Exit setup and check again.
If you need any more assistance feel free to contact me through fixya.
regards
Ajin
Feb 05, 2011 | Denon AVR-3806 Receiver
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Phone getting switched off when speaker is turned on
(Just received this from Panasonic Support...Thanks Panasonic!) The following might be worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Dec 21, 2008 | Panasonic KX-TG4321B Cordless Phone
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Nov 16, 2008 | Pioneer DEH-1600 CD Player
Creative Labs Creative Technology Zen MP3 Player Logo
140 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
