Question about Maytag MGC5536 Gas Cooktop
Ignition keeps on flickering
The ignition suddenly starts flickering at all times(all four burner at the same time), what do i need to do to stop it, we have to disconnect it from the plug so it doesn't contiinue flickering but as soon as we plug it again, it starts to flicker. what could be the problem?pls help
    Novelist:
  • 222 Answers
Clean the bottom of the knob by using vacium,remove the knob,pii it hten clean the area of the gas valve wen the knob possition,then return the konb
tnx gerbee
Posted on Jul 04, 2009
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Clicking on one of the burners
sound like the spark switch got wet or has failed, if it has gotten wet from cleaned to stop the clicking unplug the ct of 24 to 48 hrs to allow time to dry out if that does not work call a appliance service company
Jun 03, 2008 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Open Questions:
Maytag MGC5536 Gas Cooktop Logo
411 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
