Question about GE WBSR3140DW Top Load Washer
Water pump goes through the whole cycle with door open.
This is my first washing machines that will not stop going through the whole cycle with the door open. I have lost so much washing powders with this washer. All other washing machines that I ve owned would fill up with water and then stop until I closed the lid. I would always start my washer when I start putting clothes in and usually go over the house making sure I had everything and sometimes I forget and when I go back, it will havve gone through the whole cycle and boy does that make me mad. I have cussed this thing a many of a times. I never called the service man cause I just figured they changed them. I am just curious and want to know if they did. If they did, I would advise them to go back to the old way. Does anyone out there know????? I have had my washer since 2005. That s how long I ve been going crazy. HaHa
    President:
  • 3,113 Answers
You can replace the lid switch to fix it. The best thing to do is sort your laundry first from all over the house where you left the items. Make a load sized pile and place in washer along with the detergent and then turn on washer. If the switch has been straight wired it will do this. The switch on mine is straight wired and I have no problems with it. The lid switch is on there to keep small children and arms from getting hurt and broken.
Posted on Jun 29, 2009
  • honeymokey
    honeymokey Jun 29, 2009
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
When i turn the dishwasher on it start but when it whant's to wash the two red lights goes on and machine beep and stop washing.
After the intital cycle of the water inlet vavle opening the program shifts to the next mode But since there is errors on the controller the machine shuts off with an alarm.
Now check the front door opening switches, check the washer pumps, check the drain cycle/pump.
remove and check the door switch contacts, the pump and the drain.
Jun 14, 2011 | Dishwashers
My washing machine will not drain the watere
CHECK PUMP/SEE IF ANYTHING STOPPING FROM PUMPING OR IT PUMP IS BAD,CHECK CLOGGED DISCHARGED HOSE ..
FRED
Feb 14, 2010 | Indesit W 123 Front Load Washer
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4 washer won't drain. gets code f02
take bottom panel off ,,it has a screw out filter,,this filter fits directly in your pump..its clogged,,your pump is the fist part you see when you open bottom panel
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
49 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
