Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer will agitate but will not drain.
Washier will agitate but will not drain
  • 286 Answers
Sounds like you have either something in the pump or a bad pump. You will have to open the console and lift the face up so you can remove the clips. After the clips are removed then pull the cabinet right off. Then you can get to the pump. Just remove the 5/16 screw and clips on the pump and pullpump off. Remove the hose and look inside. If nothing is blocked then you will need to replace the pump
Posted on Jun 29, 2009
My kenmore washier is showing a code f21 when it gets ready to drain. it's a kenmore elite 5
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Jun 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have an estate washier & it makes it too the rinse cycle & stops. Any ideas why?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Whirlpool Washing Machines
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washier problems
Check pump belt or restriction or kinked hose
Oct 21, 2009 | Maytag PAV2300 Top Load Washer
Washier 70 series,
Assuming that this is a basic Kenmore / Whirlpool top load, direct drive neutral drain machine.
See the Sears parts list for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of sub components will come up.
This type uses a reversing motor to directly drive the drain pump and the transmission in spin mode.
If the machine agitates, the motor and transmission are probably OK.
If the Timer, doesn't send the signal to the motor to Reverse, neither the pump, nor spin will occur. Therefore, it seems as if it is a timer problem.
The smell may be coming from a part called a Motor Coupler.
This device has three parts, two of them are plastic with prongs. Each of them slides onto shafts on the motor and transmission. Between them is a rubber piece with six holes used to line up the prongs and as a fail safe. If the motor or transmission jams, the rubber piece will break saving the motor and transmission.
I'd also look at a Whirlpool installation and maintenance document which describes how the washer works in great detail.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Sep 13, 2009 | Kenmore Washing Machines
Lent on clothes
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
97 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
