Question about Microsoft Arcade Unplugged for Xbox
I have new arcade unplugged not open and it will not work
  • 3 Answers
It was probobly defective so take it back and get a new one
Posted on Aug 07, 2009
I BOUGHT A PAC MAN MACHINE THAT THE MONITOR STOPPED WORKING ON. EVERYTHING ON THE MACHINE WORKS EXCEPT i CAN'T SEE ANYTHING ON THE TUBE. I WOULD LIKE TO FIX MY MACHINE
If this is a CRT type of arcade video game, it most likely uses an old-school flyback transformer, and a bunch of electrolytic capacitors. Check for cold or dry solder joints on all the boards (with the unit unplugged), and retouch any suspicious ones; especially the pins on the flyback, the CRT neck board/socket (if applicable) and in the power supply sections, where heat may be generated. Also check to see if the filaments light up in the CRT neck. It's also a good idea to check the caps in the power, horizontal and video sections as well - look for bulging or ruptured electrolytics, and/or burned resistors. Some arcade games (e.g. Asteroids) use a HV diode rated at around 25-30kV (it is located near the flyback and may have an insulated plug at each end). These can crack, short or simply go open circuit producing a "no display" symptom. If your game has this, check it before condemning the flyback or caps (the diode also doubles as a HV fuse). Do all the basic checks/visual inspections that you can thoroughly first before going any further with repair and/or restoration. It could be something really simple and easy to fix and/or obtain parts for (at reasonable cost if necessary).
Dec 29, 2013 | Arcade Toys
I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
After doing this try to check your power supply and see if it is working well..
see if the board look´s like this:
Note that some versions has ide hdd interface.
to help you, i find the service manual with all the instructions in this link
There is a step by step guide to fix your Golden tee!
Good Luck!
Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
Need manual for Hydro Thunder arcade
http://www.arcade-museum.com/game_detail.php?game_id=8161
hopefully that will help you with whatever your looking for
Mar 29, 2010 | Arcade Golden Tee Unplugged Video Cabinet
Halo3 and game freezes GTA IV as well
Try using a DVD cleaning disk, It's odd that it would have a dirty lens if it is somewhat new still. Also, try seeing if it freezes when you turn the xbox on (with game inside) by using the main button on the console. For some reason certain games will freeze randomly if you turn your system on with the controller (I'm not sure why yet)
If that doesn't work, you will most likely need to contact microsoft, a new game should not stall a new xbox. Your xbox should be under warranty for internal issues ( Don't open it yourself )
Dec 27, 2009 | Microsoft Xbox 360 Arcade
I need someone to install a 60-1 pcb
If the arcade machine is Jamma and the 60-1 board is Jamma then it should be as easy as unplugging the old card and plugging in the new card. The Jamma bards plug into a dual row 28 pn connector. Check out http://www.jammaboards.com/jcenter.html for Jamma board details and to see if your current machines are really Jamma compliant. If it were me, I would verify the supply voltages on the connector before you install the new board.
Sep 18, 2009 | Video Game Consoles & Games
Play dvd, and it freezes!
go to the acer website and see if there is a new update for the bluray player.
Aug 12, 2009 | Computers & Internet
Arcade umplugged volume 1 wont play
i think iv had this one you put disc in then when its loaded goto arcade menu and i think the games are there rather then reading from disc
May 09, 2009 | Microsoft Arcade Unplugged Volume 1 for...
Repair Service Arcade games
i have fixed arcade games since 1990. let me know what you need: (happycarnivore@yahoo.com)
Feb 25, 2009 | Arcade Golden Tee Unplugged Video Cabinet
Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
Dec 26, 2008 | Microsoft Xbox 360 Console
Multiplayer ip
If you need to open ports on your router just follow the manual. If you need one just add a comment and I'll get right back to you. If this doesn't work do the same. Go slow and follow instructions. This should fix your problems. Keep track of what you do so it can be undone to start fresh just in case this doesn't work but it should.
Firewalls
GameSpy Arcade is 100% reliant on your Internet connection being fully functional. The same holds true for any games that you want to play online against other people. Firewalls and proxy servers are designed to block your Internet connection in order to minimize the chances that your computer will be accessed (or hacked!) by "unwanted visitors." They also have the unfortunate side-effect of disabling many of the things you might want to do online -- like play games -- since these activities depend on your PC making an unimpeded connection to other computers. Therefore, if you are using a firewall or proxy, Arcade may not function properly nor will you be able to download and install all of the files that you need in order to use the software to play games online.
Connecting to different places online requires access through "ports" in your PC's Internet connection, and firewalls and proxies will close certain ports for your protection. This is not always necessary, but you as the firewall/proxy owner are the only one who can open those ports. We can't do it for you - but we can give you some tips on how to configure your firewall / proxy to allow Arcade to work properly.
What is a firewall or proxy?
Firewalls and proxies are software programs or pieces of hardware designed to protect your computer and/or network from Internet intruders. Some of these are:
  • Windows XP Firewall
  • Norton Internet Security
  • Tiny Personal Firewall
  • Zonealarm
  • Sygate (proxy)
  • Wingate (proxy)
  • Internet Connection Sharing aka ICS - provided by Windows 98SE and higher (proxy)
  • Linksys Routers (hardware firewall)
  • D-Link Routers (hardware firewall)
  • Cisco Routers (hardware firewall)
Working Around the Firewall / Proxy
If you are behind a firewall/proxy and are able to change its settings, Arcade needs the following TCP ports open in order to function:
  • 6667 (IRC)
  • 3783 (Voice Chat Port)
  • 27900 (Master Server UDP Heartbeat)
  • 28900 (Master Server List Request)
  • 29900 (GP Connection Manager)
  • 29901 (GP Search Manager)
  • 13139 (Custom UDP Pings)
  • 6515 (Dplay UDP)
  • 6500 (Query Port)
    Disabling firewalls will not work
    Unfortunately, in most cases, firewalls/proxies cannot simply be disabled in order to allow you to use Arcade and your game. Disabling the firewall / proxy will not open the necessary ports. It will simply shut down the firewall/proxy and leave the ports closed. Also, many factors may conflict with your firewall: Internet Connection Sharing, the use of more than one firewall, or your operating system may all cause conflicts that keep you from enjoying Arcade.
  • Special notes to Windows XP users:
    Windows XP has a built-in firewall. If you are using 3rd party firewalls/proxies with Windows XP, you will have to consult both the firewall/proxy developer and Microsoft to determine their compatibility with one another. You will also need to speak to your game's developer in order to determine the game's compatibility with WindowsXP, its firewall and your 3rd party firewall/proxy.
    Disabling / Setting Permissions on Specific Firewall Programs
    We do not recommend disabling your firewall. Disabling it will not make it open up the ports it has already closed. Instead, you need to configure it to allow access to Arcade. This is usually called "giving permission," and can be accomplised quickly by following these steps:
  • Windows XP Service Pack 2 -- The built-in firewall that comes bundled with Windows XP will affect two areas of your Arcade experience: 1) Arcade itself (including the login process, using PlayerSpy, chat, using the Download Manager and playing games) and 2) Hosting any parlor or peer-to-peer games. In order to use Arcade and play games properly with Windows XP, you should follow these steps:
    1) Unblocking GameSpy Arcade During Login: Click the "Unblock" button in the Windows XP firewall prompt the first time you attempt to log into Arcade atfer installing Service Pack 2
    2) Unblocking GameSpy Arcade via Control Panel: If you forgot to click "Unblock" in Step 1, or if you want to be ahead of the curve, you can configure the XP firewall to unblock Arcade via the Windows Control Panel. To do this: Click on Start > Settings > Control Panel > Windows Firewall. In the Windows Firewall menu, Click on the Exceptions tab. If GameSpy Arcade is not listed, Click on the Add Program button, find GameSpy Arcade on the list of available programs and click the OK button.
    3) Unblocking Your Games: This can be done in one of two ways: a) Either wait for Windows to prompt you to unblock the game and click the Unblock button (this usually happens the first time you attempt to host a game after installing Service Pack 2, or; b) Use the Windows Control Panel to add the game to your list of Exceptions, using the same method listed in step 2 above.
    4) Unblocking Ports: You can take the unblocking process a step further by instructing Windows to open the Firewall to all ports used by GameSpy Arcade and most of its supported games. To do this: Click on Start > Settings > Control Panel > Windows Firewall. From the Windows Firewall Menu, click on the Exceptions tab, then click on the Add Ports button. From the Add Ports Menu, enter a port from the list of ports at the top of this Arcade support page. Be sure to indicate whether this is a UDP or TCP port (the list above should indicate which it is).
Feb 12, 2008 | D-Link SWT DSL-504T ADSL MODEM with 4...
Microsoft Arcade Unplugged for Xbox Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
