Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
How to fix sony tv v stop - Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Bravia 55'inch led volume controls stopped working. Remote or tv button don't adjust volume
Volume is controlled by the main board. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix it yourself. It's easy.
May 10, 2017 | Sony Televison & Video
Hello Everyone , I have a sony 34XBR960 that stopped working so I had a TV repairman check the TV and he said the Q-Block was defective so I found a TV on craigslist , it's a sony 34XBR970 that i
To make sure, you have to download the service manual to both models. Ask the service man to do this. Then he can compare both schematics, and make sure about the compactablilty.
Jun 20, 2012 | Sony KV-36XBR400 36" TV
Sony 50" rear projecion TV has a green picture
sounds like one of your color projectors might of stopped working. leave the tv plugged for 5 minutes and try to turn it back on... if that doesnt work then i would check slickdeals.net for a new tv its cheaper to buy a new tv than to fix it..
Jul 11, 2010 | Sony Televison & Video
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
TV won't turn on
There's a small diode on the power supply board that causes this. Its identifiable by its purple stripe. You will need the correct type of diode to fix this properly. The diode supplies the standby voltage to the system control circuit, so when it fails, the TV will never come on.
michtech
Feb 12, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Oct 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
10blinking model KVHX32M31
You should contact an authorised Sony repairer as they have a fix which took abot half an hour to solder in a replacement part which had been damaged by over-heating. Ours was fixed under extended warranty.
Oct 22, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
