Question about Kenmore 71121 Air Conditioner
Reverse unit. Heater only blows air, not warm air
The heat goesn't work on my Kenmore reverse cyclw ac unit. It blows air, but doesn't get warm at all.
  • 49 Answers
Re: reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Posted on Nov 08, 2007
0 characters
3 Points
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
Heat/ac window unit not blowing warm air
if its the old fan coil system it needs replaced but if its the new heat pump type you need to find the reverse solanoid and just tap it a few times while in the heating cycle till you hear it click they do stick sometimes
Dec 09, 2013 | Frigidaire Air Conditioners
Frigidaire heat/AC window unit will not blow warm air
if you still have the old heater element its done but if yours is the new heat pump system you need to find the reverse solanoid and just tap it a few times with the handle of a plastic screwdiver till you hear it click these solanoids do stick if you havnt used the heater for a while
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
Jan 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Kenmore 71121 Air Conditioner Logo
1,003 people viewed this question
Top Kenmore Air Conditioners Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Kenmore Air Conditioner Expert? Answer questions, earn points and help others
