Question about Intel Motherboard
Turns on then off in less than 5 seconds
Im thinking prob missing some jumpers i need setup manual and power source info
    President:
  • 987 Answers
First check the RAM modules sit properly ...
Posted on Aug 11, 2009
Bios password Dell XPS M170 how do you unlock it ???
How to use the jumper to reset the BIOS password on your Dell desktop computer
Summary: If you're prompted for the Basic Input/Output System (BIOS) password at startup (before the operating system loads) or the BIOS or CMOS setup is locked, and you don't know or have forgotten the password, you won't be able to use your computer or change BIOS settings. Use these instructions to reset the BIOS password manually using the jumper.
NOTE: This process will not clear a Windows Operating System password, nor will it clear passwords on a Dell portable computer. This is only to clear System BIOS passwords on Dell Desktop and Mini-Tower systems.
Desktop system BIOS password reset.
NOTE: The BIOS is the program that activates the hardware required to start your computer. The jumper is a small plastic covering found inside your computer.
Before you begin
Perform the safety steps in the order below.
WARNING: These steps are for your personal safety and the protection of the equipment.
  1. Turn off the computer and unplug the power cable.
  2. Wait 5 seconds.
  3. Disconnect all external devices.
  4. Disconnect any telephone or network cables from your computer.
  5. Press and hold thePowerbutton for 10 seconds while your computer is unplugged to release static electricity from the system.
  6. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
To use the jumper to reset the BIOS password
NOTE: On the DellManualsweb page, download the Setup Guide or Service Manual for your computer. Then refer to the System Board Components section for a labeled illustration of the jumpers on the system board.
  1. Ensure that your work surface is flat and clean to prevent scratching your computer's cover.
  2. With your computer still turned off and unplugged, remove your computer's cover.
  3. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  4. Choose an option:
If there are 2 metals pins under the jumper
  1. Remove the jumper from the pins, replace the computer cover, reconnect the power cable and monitor and turn on the computer.
  2. After the Windows logon screen appears, turn off the computer.
  3. Again, disconnect the power cable and monitor. Press and hold the power button for 10 seconds to release static electricity from the system.
  4. Remove your computer cover.
  5. Replace the jumper in its original position covering the 2 pins. This will re-enable password feature.
  6. Replace the computer cover.
  7. Reconnect the power cable and other connections and turn on the computer.
If there are 3 pins under the jumper (See figure 1. below.)
Figure 1. Generic motherboard illustration showing a 3 pin password jumper, you motherboard may vary, see the owners manual for you system for specific instructions.
  1. Remembering which two pins are covered, remove the jumper from those pins.
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
  4. Turn on the computer and wait 5 seconds. Then press and hold thePowerbutton until the computer turns off again.
  5. Disconnect the power cable and monitor again. Press and hold thePowerbutton for 10 seconds to release static electricity from the system.
  6. Replace the jumper over the original 2 pins.
  7. Replace the computer cover.
  8. Reconnect the power cable and other connections and turn on the computer.
May 06, 2017 | Dell Computers & Internet
I ned to unlock the bios psword for dell latitude e6420
The solution depends on whether your laptop was made before or after 2004. If it is a post-2004 model, you must call Dell Support to reset the password for you.
If it is a pre-2004 model, you can follow these steps:
Warning: these steps are for your personal safety and the protection of the equipment.
    Turn off your computer, and then unplug the power cable.
  1. Wait 5 seconds.
  2. Disconnect all external devices.
  3. Disconnect any telephone or network cables from your computer.
  4. Press and hold the Power button while your computer is unplugged to dissipate static electricity from the motherboard.
  5. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
Note: On the Dell Manuals page, download the Setup Guide or Service Manual for your laptop. Then refer to the System Board Components section for a labeled illustration of the jumpers on the motherboard.
  1. Ensure that your work surface is flat and clean to prevent scratching your laptop's cover.
  2. Remove the battery from your laptop.
  3. With your laptop still turned off and unplugged, remove the cover.
  4. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  5. Choose an option:
    1. Remove the jumper from the pins, replace the cover, reconnect the power cable and turn on your laptop.
    2. After the Windows logon screen appears, turn off your laptop.
    3. Again, disconnect the power cable. Press and hold the power button for 10 seconds to release static electricity from the system.
    4. Remove the cover.
    6. Replace the cover.
    7. Reconnect the power cable and other connections, replace the battery and turn on your laptop.
    3. Replace the cover and reconnect the power cable.
    4. Turn on your laptop and wait 5 seconds. Then press and hold the Power button until it turns off again.
    5. Disconnect the power cable again. Press and hold the power button for 10 seconds to release static electricity from the system.
    7. Replace the cover.
    8. Reconnect the power cable and other connections, replace the battery and turn on your laptop.
    You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your laptop's service manual.
Nov 23, 2013 | Dell Latitude E6420 PC Notebook
Jumper setting vor motherboard setting in computer
AsRock Support > P4i65G > Main Support page,
http://www.asrock.com/mb/Intel/P4i65G/
In the top left column under the green AsRock name, click on - Manual in the list.
To the right of - User Manual - click on the country NAME nearest yours.
When the PDF file comes up........
Hover your mouse cursor at the bottom. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" will briefly appear)
Click on the Zoom Out icon ( - ) at the top, to Decrease the view size.
Use the Zoom In icon ( + ) to Increase the view size.
The Adobe Reader page number box, is to the right of the Down Arrow, at top.
Page 9 shows a Motherboard Layout, and the jumper locations.
Page 15 has the details about the jumper settings.
Motherboard installed in computer case;
A) At the Top/Left corner is PS2/USB/PWR1 jumper
There are 3 pins.
Starting on the LEFT side going towards the Right;
Pins 1, 2, and 3.
Jumper cap on Pins 2 and 3 for +5VSB
+5 Volt StandBy power.
It is for PS/2 or USB Wake-Up events.
Suggest leave on Pins 1 and 2.
B) To the Top/Left corner of the top white PCI slot, is the JR1JL1 jumper.
4 pins going across.
From the LEFT side going towards the Right;
Pin 1 and Pin 2 for JR1.
The next two pins are Pin 1 and Pin 2 for JL1.
If there is a jumper cap on those pins, your Front Panel audio ports, and Rear panel audio ports will not work.
(JL1 = Front Panel JR1 = Rear panel. The rear panel is also the I/O area. Input/Output. Where the mouse, keyboard, monitor, etc hook up)
C) Right below the round CMOS battery on the right side, is the
CLRCMOS0 jumper.
Clear CMOS jumper
NO jumper cap on those 2 pins to operate the motherboard.
"CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes system setup information such as system password, date, time, and system setup parameters.
To clear and reset the system parameters to default setup, please turn off the computer and unplug the power cord from power supply.
After waiting for 15 seconds, use a jumper cap to short two pins on CLRCMOS0 for 5 seconds."
Regards,
joecoolvette
Jan 03, 2013 | Asrock P4i65G Motherboard
I need to see specifications for TYAN S2925 motherboard
JP5 Jumper is the reset jumper... Look at this Pdf:
ftp://ftp.tyan.com/quickref/q_s2925_100.pdf
Jun 30, 2012 | Tyan TOMCAT N3400B S2925 S2925G2NR NFORCE...
Changed lan settings in post now my bios and xp wont launch
Turn the computer off.
Disconnect the AC power.
Look closely at the motherboard.
Look for 3 pins in a row, with a jumper between 1 & 2.
This is the "BIOS RESET" control.
Move that jumper to connect 2 & 3, for 5 seconds.
to reset the BIOS to its "default" settings.
Move that jumper back to to the 1 & 2 position.
Reconnect the AC power.
Turn the computer on.
Enter BIOS SETUP, to confirm that the "default" settings have been restored.
Oct 23, 2010 | Computers & Internet
When i plug in my power cord the computer turns on by itself, also my vr and cpu leds are lit up ive tried removing the battery and also removed the jumper. is there anything im missing?
Yes--in the CMOS settings (when you press Del or another key on startup--it prompts you to do this to enter setup) you need to find the power settings. Should be the ACPI settings. You computer is probably set to restart after a power interruption. Turn that off.
Nov 04, 2009 | Intel D945GCZLKR (BLKD945GCZLKR)...
Unable to strart windows
Clear Real Time Clock (RTC) RAM by way of the jumper. This jumper allows you to clear the RTC RAM in CMOS. To clear RTC RAM :
  1. Turn off the computer and unplug the power cord.
  2. Open the chassis.
  3. Remove the on-board battery.
  4. Move the jumper cap from pins 1-2 (default) to pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
  5. Reinstall the battery.
  6. Plug the power cord and turn on the computer.
  7. Hold down the <DEL> key during the boot process and enter BIOS setup to re-enter data.
  8. Start setup again and make sure your setup disc is not corrupted.
Aug 23, 2009 | E-Machines T2893 PC Desktop
Bios password set
remove battery, boot to system settings, re-insert battery, CMOS PW should now be cleared
Jun 11, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Chassis intruded asus m3a78-cm
I actually did a little research on this one. I downloaded the User Manual for this board. USUALLY, there is a jumper on the board somewhere that needs to be set in the correct position. I looked through the manual and can't find a jumper for this . I even looked through the bios setting just in case it might be covered there, no luck. If you can't find an undocumented jumper on the board somewhere labeled something like TRPWR, then I would try the reset next. My suggestion would be to use the LCRTC jumper to reset the board. Heres the procedure according to page 1-17 of your manual:
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values.
Feb 22, 2009 | Dell Dimension 4600 PC Desktop
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
