First of all you have to remove the knob the get a deep well socket that will fit it.remove the nuts and your switch should pop out to the inside of the unit.Now hold it in your hand and look at it. You have to replace the wires from the old switch to the new switch in the same manner they are attached now. Once this is done try it out out first to make sure it works then reinstall it the same way you took it out. Good luck
IGNITION SWITCH REPLACING
It
depends on vehicle to vehicle. But it's not very difficult on mot of cars to
replace ignition switch. Basic theory of replacing ignition switch is same for
all car models. -----
To
replace ignition switch on your vehicle, I suggest you
few helplinks with proper ignition switch replacing procedure.
View its details and you can replace ignition switch on your
vehicle.
Click
the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on
Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Ford Taurus: Ignition Switch & Steering Column Replacing?
How to replace Ignition Switch on Acura Car Models?
How to Replace Ignition Switch on Chevrolet
Caprice Classic?
1995 Ford Taurus: Ignition switch not turning OFF?
Ignition Switch Will Not Turn Off?
These will help.
Thanks.
