Question about LG Flatron L1919S LCD Monitor
Screen not sharp for text - LG monitor attached to macbook - can not seem to sharpen
    Scholar:
  • 106 Answers
Click on the apple symbol
click on system preferences
click on displays
make sure you have mirror turned off. increase the resolution on the second display to higher resolution.
it should detect the max available resolution if you press the detect display button
Posted on Jun 29, 2009
How to Degauss
LCD flat panel monitors do not have or need a degauss function. The older CRT monitors had the degauss button to remove any magnetism that built up in the metal frame that would cause distortion. LCD monitors do not rely on magnetic fields so no degauss button. If your display is showing strange patterns and text the most likely cause is a bad video card. First try a different monitor on your card. I would bet the display is bad on it too. It you find this problem just replace your video card and the issue should go away.
May 16, 2013 | LG Computers & Internet
No image on screen
Make sure the monitor is working first. Try hook it up to a regular PC. If it works on a regular PC then make sure your Macbook's output is setup to show the video onto an external monitor.
If you can't get the monitor to show video on a regular pc then that means the monitor is bad.
Apr 22, 2010 | LG 22" FLATRON LCD Monitor
Overlapping text
You probably have to check the Sharpness Function on manu and set it to level 1. It will cause text opvelapping if you move it to high level.
Mar 22, 2010 | LG Flatron L1718S LCD Monitor
Text in 2ndary screen not as sharp as IMAC screen
Prior to HDMI, TV screens simply did not have the resolution of the average computer monitor. With HDMI, they can approach or equal this resolution, but it isn't always easy to set up, and a certain amount of individual experimentation is necessary. Here is a guide I refer my own clients to when they are attempting this.
http://www.ehow.com/how_2321697_use-hdtv-as-computer-monitor.html
Nov 15, 2009 | Apple iMac G5 Desktop
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
Monitor non functional
Am I correct in understanding that your MacBook is operating properly, but when you attach your external monitor it doesn't show anything?
I often connect my black MacBook 2GHz to my flat screen's VGA port. Sometime the screen doesn't respond for one reason or another. The fastest solution is typically to mirror the screens then return to normal. When that doesn't work, it's usually enough to restart the MacBook while it's still plugged in to the external monitor. If neither of those work, try connecting to a different monitor or finally try replacing the connector.
Unfortunately those connectors don't have the best life spans. (See Apple's customer reviews on DVI connectors.)
iKnow Apple Dan (919) 280-3101
Aug 02, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Contrast
The supplied software should allow you to set brightness and contrast if there are no front panel buttons to set it.
Check for LG or Flatron programs under the Programs listing available from the Start panel.
Jun 19, 2008 | LG Flatron L1710S 17" LCD Monitor
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
LG Flatron L1919S LCD Monitor Logo
918 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
