Question about Garden
Toro Model #71227 16-38HXL when I pull up to engage the blades, the engine stops. If i turn the reverse backup key it will stay running
SOURCE: 5500 FS craftsman tractor electical cutout switch problem
A jumper wire (insulated) can be TEMPORARILY connected across each switch (assuming it has two wires) to short out the switch (completes the circuit), one switch at a time. Then try to start the mower, and if it starts and runs, you have just found your bad switch.
I do not advise using the mower until you get the switch replaced . . . the safety switches exist for your protection.
Posted on Apr 11, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 4 Answers
SOURCE: dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
Posted on May 18, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
Why won't the wheels move forward or backward on my Toro 54" Zero Turn Lawnmower. Was mowing and it stopped moving.
usually if the pins are pulled out that is the freewheel position. push them in to drive. if the trans locks in drive and it is hard to push it should be ready to mow. unless the drive belt is stretched or broken or a linkage is out of adjustment or broken.
Jun 01, 2018 | Toro Garden
Toro mower model 20333 starts but stops running when blades are engaged.
i dont know how many pressure switches on a torro but the one on the engagement arm should be checked first sounds like it may be bad to check jus wire them up direct.
Sep 23, 2017 | Toro Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Looking for the location of the clutch safety switch on an older toro commercial 11-32
Anytime your engaging blades it pulls quite a bit of juice from the battery, so you need to be absolutely sure your battery is good.
Jul 26, 2014 | Toro Garden
My craftsman mower shuts off every time the blades are engaged. What is the problem?
you most likely have a shorted or open safety switch. you did not mention year or model # so I can only guess what configuration you have, but typically there are the following safety switches on a riding lawn mower: clutch/brake on switch (under floorboard at clutch, this allows you to get off the tractor with engine running if brake is applied), Reverse gear safety switch (will shut engine off if attempting to go in reverse with blades on...follow the gear handle rod down to transmission, may be internal or external of differential), there is also usually a disable switch to allow blade operation in Reverse and this is usually relay operated via a button or turn of the key position, Seat safety switch (under seat and usually is disabled via engaging the clutch/brake switch, this switch will kill the motor if you come off of the seat unless brake is applied), and of course a switch that is tied in to tell when blades are engaged (engage handle or PTO switch). It is actually simpler than it sounds and you dont' need to be an electrician to figure it out. start out with a visual inspection of the switches that you can see. I would suspect the transmission position (reverse) switch first, do you have an override? if so, turn it on and see if engine stays running with blades engaged. hope this helps and here is a link to a company that deals mower parts and has alot of great parts breakdown illustrations online. A craftsman is pretty much the same as a MTD or White Outdoor model, so look those up and it will show you the areas where switches are.
http://www.superxpower.com/pages/parts/viewbybrand/55/HusqvarnaPowerEquipment.aspx
Apr 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
466 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
