Question about Sport & Outdoor - Others
1995 Apollo Spa 10,000 volt Thunderbolt-motor won't restart
1995 Apollo Spa 10,000 volt Thunderbolt electrical. Repalaced the wetend on pump. Motor does not now restart.Power to main switch. Power out of switch on each leg. Power from switch to timer, but nothing seems to go past timer on that leg. Where do I get my hands on a wiring schematic, or what can I check for nex?
  • 1073 Answers
SOURCE: Estate dryer won't come on..
check the white thermal fuse on the blower housing
Posted on Apr 26, 2008
freetek
  • 5568 Answers
SOURCE: Secondary air injection pump, 01 GMC Jimmy V6
You didn't mention the fuse rating of the one you replaced so this method may not help if it was higher than ~5 amps.At this point, I would wire a 12 volt bulb, preferably, one with 40-50 watts rating (headlamp will do fine) in place of the fuse that is blowing and start pulling likely connectors until the light goes out. If you don't get results this way, you might try disturbing one bundle of wire after another since this could be happening because of insulation that has been pinched or worn through to reach ground.
Using a bulb instead of bridging the fuse with a piece of coathanger will prevent melting the wire and possibly compounding the problem.
Posted on Nov 24, 2008
PartsCenter
  • 125 Answers
SOURCE: Kohler bathtub spa does not work at all
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
Posted on Feb 24, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Pool motor makes a buzzing sound but doesn't work
sounds like it has a bad capictor .. look fr a otor shop in your area that tsts them , should be free test
Posted on May 31, 2010
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
I have a Waterway Insulated wetend pump 1 HP. Model # SD-10-2N11MC It has power to the pump but doesn't work. 118 Volts per wire. Makes no noise but keeps blowing fuses. A Balboa VS501Z power unit.
You have a short some place or the motor or pump itself is shot or seized causing it to shut itself down by blowing fuses. Could be bad bearings.
See if you can turn the shaft on the motor.by hand with it not plugged in that will tell you where the problem could be. .
Apr 12, 2015 | Waterway Pool & Spa
My Apollo Spa shuts off and on when high speed is pushed. I replaced pump and it is the same. Any help is appreciated.
Check your voltage to that pump. If the pump is set to accept high-voltage of 240 V, and you are only providing low-voltage of the 110-120 V then you will be getting that symptom.
Apr 12, 2015 | Pool & Spa
What voltage should this be
look on the side of motor schematic 120 volts vs 240 volts
May 30, 2014 | Hayward 2HP Pool Pump Motor A O Smith...
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
My 4.0 hp waterway excutive pump works, the shaft spins, but no water movement, i checked for airlocks, could it be the grey propeller inside the wetend thats not working? is it worth a look inside the...
Thank you for posting your question here on Fixya.com.
Yes...you'll likely find the impeller body has broken away from the motor shaft so even though the motor turns the impeller is not. Replacing the impeller and the seal are not to hard but you may want a shop to do it if you are not familiar with seal replacement. While they have it they can make sure the motor bearings are still OK since the most common reason the impeller breaks is a seal leak that leads to motor shaft and possibly motor bearing damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Mar 17, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Am I able to step this motor down to 115 ? Plate specifies 230V.only
it depends on how many motor wires you have available to work with .. IF the name plate says 220 volts , not 120 / 220 volts , then no. If there are only 2 wires for the motor, then NO
thoughts?
Jun 23, 2010 | AO Smith 1.5 hp 3450/1725rpm 56J Frame 115...
I just bought this pump and just bought a new wetend. Everything was the same as I had before. I hooked the wetend to the pump just like before and installed it into the spa. When I turned on power,...
The wear ring on the impeller can cause all these problems. It seems natural to put this on the impeller with the wide side tward the impeller but it goes on with the wide side out so when the pump starts the ring slides forward and seals the pessure side of the impeller from the suction side. With this in wrong your water will just circulate inside the pump rather than going back to the spa. I hope this helps.
Dec 16, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Sport & Outdoor - Others Logo
114 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
