Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Lexmark 5400 series paper jam
I have a lexmark 5400 series printer. It keeps getting a paper jam- we have tried various methods from the manual to fix it....but its still happening. Please help.
  • 7 more comments
  • Anonymous Jun 04, 2008
    Our Lexmark 5400 series will not feed the paper and then it sounds like it is printing but the paper will not come out.....will not print or feed. Our e-mail address is
  • Anonymous Aug 01, 2008
    My Lexmark 5400 also keeps saying the paper is jammed. I bought this printer in April and it is only 3 months old. This started happening about 6 weeks after I bought it. What can I possibly do to have it repaired or replaced?
  • Anonymous Oct 01, 2008
    My Lexmark 5400 will not feed the paper through properly and keeps getting a paper jam
  • jmaril Oct 06, 2008
    A friend of mine has a similar problem with her X5470, in France.
    It keeps saying 'paper jam' while there is no any paper in the printer.
    I called the french Lexmark support service
    They recommanded to try resetting the machine to factory default settings, ie press the three following buttons at the same time until "Languages" appears on the menu: On/Off button + Sart color button + Cancel/Clear/Exit button (red cross)
    Nothing good happens and one even never enter the resetting menu!
    A friend of mine has a quite similar problem with her Lexmark X5470 in France
    The machine is locked for any function while the display shows a "paper jam" message with no any paper in the machine
    I asked a Lexmark support service
    They recommended to try to reset the printer to factory default settings, ie pressing at the same time the three following buttons until "Languages" appears on the display.
    Nothing good happens and we even do not enter the resetting menu!
  • Anonymous Nov 09, 2008
    my lexmark 5400 was working well when i purchased it but now 5-4 months later it keeps jamming. please help i need the printer for my courseworks.
  • mcvdberg Jan 04, 2009
    Paper feed problems here aswell.
    Have tried to open the machine to acces and claen the rolls but it is quite rigidly constructed. Who knows how to open it?
    Probably the screws next to the opening tru which you change the inkcartridges ...
    The back, three screws, seemed the place to start but no ...
    Who knows?
    Will also try the heavier paper eg. 160g/m3 and report later
  • k11ilp Apr 15, 2009
    I believe 4425-01 is part of the 5400 series. Paper feeds on one side only, and jams. Attempted to put a 1/2 width paper on bad side (my left). It seemed to collapse in until some part reached the good side, went in (that side) a little and jammed again. I would like to find a manual. I would like to be able to get to the rollers. I liked the "best" solution here but am unclear how to do it. Need manual?
    I believe 4425-001 is part of the 5400 series. Paper seems to go through on one side (my right) only, and jams. I tried to put a 1/2 width paper through on the bad side. It crumpled until some could go through the good side and jam. I would like to find a manual. I would like to get at the rollers. The "best" solution here sounds good but I can not yet fully understand how to do it... I need a manual.
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Posted on Feb 23, 2009
I'm having the same problem on the Lexmark 5400. Will print in black and white and copy in color. Any suggestions?
Posted on Dec 20, 2007
I did it. I did it. You have to put ALOT of paper into the printer. It needs heavy paper to make that lever move. Just try it.
Posted on Oct 18, 2008
For the jam check the guides under the hood, push the clips in and use a small light to look into the paper feeder area, there are two black "clips" or guides on a spring loaded lever, on my printer one guide let go and the paper kept feeding on one side only and jamming. hope this helps
Posted on Apr 02, 2008
I can : first of all, remove the drum, then report the problem the brother mfc recoder. Under theyre supervision remove the paper.
Posted on Jan 12, 2008
I installed a new color cartridge in my Lexmark 5400 Series printer and now I cannot get my computer to reconize the color, only black & white. I can copy in color though. Can you help me? Thanks
Posted on Dec 07, 2007
4 Suggested Answers
  • 1362 Answers
SOURCE: Brother 7020
it may not be able to take the type of paper you're trying to feed.
try cleaning the pick-up tires with alcohol and clean paper, if it picks up the tires are worn and need to be replaced, if not you will have to do it on the glass.
Good luck.
Posted on Nov 14, 2007
  • 158 Answers
SOURCE: False Paper Jam Message
Probably a jam sensor is dirty or stuck. Look through the paper path for a stuck plastic sensor arm, or dirt or paper dust on photocell typr sensors.Paper sensors are normally located near where paper feeds, and where it exits the machine. The paper must pass over these sensors as it travels through the machine.If a scrap of paper is left on the sensors, they will report it as a jam. If you can, try manually pushing a sheet of paper through the printer, ONLY in the direction it normally feeds. This may free up a stuck sensor arm, or force out the jammed scrap.
Posted on Jun 09, 2008
  • 586 Answers
SOURCE: ive a brother dcp
Hello there,
The kind of paper you use on the printer really matters as it detrmines a lot whether the printer will jam or not. When removing the jammed paper simply try to slide it out by using your hand to pull out the jammed paper. The weight as well as density of a paper can be a means of it. Definitely try regulating a heavier class paper that's a smallest of twenty-four Lbs.
Then check the rubber that rolls the paper in the direction of printing. If it is loose or worn out, the printer will continue to jam until it is fixed.
Check the blue dial in the paper drawer to see if it is set to the correct paper size. LTR means the paper is sitting in the drawer straight up and down. LTR-R means the paper is lying sideways in the drawer. When these dials are incorrect it can cause the machine to jam or give false jams.
Hope this helped. Goodluck Elect_Comp
Posted on Aug 30, 2011
Paper jamming
Try disconnecting for a while and see if it resets.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark x5495 will not print. I get the message enable bidirectional communication. I am running XP operating system. What is the solution?
Go to Control Panel > Printers and Faxes > right click on the Lexmark 5400 Series print object > Properties > Lexmark 5400 Series Properties window pops up, click on Ports tab > place a check mark in Enable bidirectional support by clicking in the box beside it. Hit Apply and click Ok to save the settings. Try to print. If problem persists, disconnect the printer usb cable from computer, uninstall the software completely by clicking on Windows logo Start menu > All Programs > Lexmark 5400 Series folder > Tools > Uninstall. Restart pc. To reinstalI, I recommend you use the software you can download from the Lexmark website. Just click on this link: Download and install the software. Follow the instructions. Try to print again. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 04, 2010 | Lexmark X5495 All-in-One &USB...
Need users guide for lexmark 5400 series all-in-one lexmark 5495 4-in-1 fax & photo features
user manuals and other documents are available for your printer at
Let me know if you need anything else. Thanks,  Ekse
Mar 04, 2009 | Lexmark X5495 All-in-One &USB...
On the 5400 lexmark if a paper jam occured, how do you fix it,do you have to unscrew the back in order to get the paper that has jamed?
No just pop of the back tray and you should have access to it from there. Make sure though to unplug your Printer and your printer need you to reset it.
plz rate thank you
Sep 07, 2008 | Lexmark Office Equipment & Supplies
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
My lexmark 5400 keeps saying "clear carriage jam". I cannot see anything jammed but i can't use it till whatever is cleared. please help!
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
If the error exists .. then printer is defective contact lexmark ..
Mar 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
2,445 people viewed this question
James Cagle
James Cagle
Jim Keysor
