Question about Zebra Eltron P520 High Speed Printer/Laminator (P/N P520C-E000U-ADO)
I got a problem with Zebra P520. when printing a card the printer feeds the card in an moves it to the printhead. Then it stop moving the card and show the error message "mechanical error". Please suggest me the possible causes and solutions for this problem.
Buenos dias , alguien tiene los driver de la zebra p520c
Posted on Nov 20, 2014
...hello...please check the settings of your printer...sometimes, this problem happens when the printer have encountered a problem while printing...(example: while printing, the ribbon itself stick to the card)....i suggest the best thing to do is to contact your supplier, because sometimes some technical (internal parts) were dislocated or damaged...but, try this first, just always remove the ribbon and place it again, and make a multiple test prints...it works, i've encountered this problem before...
Posted on Jul 06, 2009
  • 121 Answers
Hi
This error means that your printer machine is not working correctly so I would suggest you to go to the vendor.
Posted on Jun 29, 2009
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Dear Sir, My name is Muhammad Farrukh from Saudi Arabi (El-ajou Group ) I have one Zebra Printer Model : Z4MPlus Error message is coming : HEAD OPEN although it is close. if it need to replace any...
it is possible that the sensor is far from the printhead, just move the small crone plate with the small sensor, down or up, moving close or far from the printhead. if didn't fix, move the red bits from the top of the printhead to the left or rigth side, making more pressure . if didn't work, move all the printhead mecanism dont or ul, (3 srews on the left and one srew unther the printhead, next to the sensor.
Jan 06, 2011 | Zebra Z4Mplus Label Printer
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
I have a blank line across all the cards
If the line is across the card from end to end on the long side in the same spot every time, then try cleaning the printhead. If it is still there then you most likely need a new printhead.
Jun 26, 2009 | Zebra P330i Thermal Card Printer
Zebra P240i will not print test card or feed cards
i need the cardfive driver for my zebra P420i card printer.
May 28, 2009 | Zebracard P420I Thermal Card Printer
Keeps printing on 1 spot
I am a bit unlear of the QUestion Here.
But let me say it sounds as if it it tring to print in color.
The back and forth motion is what tells me that.
Feb 14, 2009 | Zebra Eltron P310 Thermal Printer
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Error message
Issue related stuck due to objects such as paper or plastic. make sure its clean and gears are moving.
Good luck
Jun 17, 2008 | Zebra Eltron P520 High Speed...
Zebra Eltron P520 High Speed Printer/Laminator (P/N P520C-E000U-ADO) Logo
361 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
