Question about Sony Handycam DCR-TRV250E Digital Camcorder
When I playback the picture pixelates in three horizontal lines
I have converted 15 tapes to DVD. The last 4 have three horizontal lines appearing. Is there a solution. Sony DCR-TRV230E
  • 73 Answers
Cleaning problem .u put one cleaning casset
Posted on Jun 29, 2009
Plz help me- 4 white small bars on my LCD Nikon D5100
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 21, 2012 | Nikon D5100 162mp Dslr Camera 1855 Dx Vr...
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Static in playback of VCR on Panasonic DMR -EZ47V DVD/ VCR combo.
First make sure the cable on the back has the center pin and its in nice and tight.I would also try another VCR on the same line that way you can eliminate that first.Then if that doesn't show a problem it maybe a internal problem with a lose solder joint.Also I was wonder does the horizontal lines appear when you use a prerecorded tape.If it does you may need to clean your heads on the VCR.
Jul 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Horizontal bars on playback plus sometimes no recorded picture
Not a solution sorry, but just to note that I have the same problem on TRV30e. It's intermittant an relatively rare, so haven't bothered getting it fixed. Seems related to certain types of DV tapes - if I change tape the problem often goes away.
Oct 28, 2007 | Sony Handycam DCR-TRV30E Mini DV Digital...
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Mar 31, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony DCR-TRV230E Digital 8 Playback Problem
Hi! If the images you are capturing are hazy with zig zag colors etc...the imaging IC is faulty.If the problem in Display unit only but the captured image is OK when you transfer the same to PC..then LCD may be having problems. We can help you in spares of Sony and we can also offer the service manual. Kindly let me know after your examination. Regards, Sivaram.V Videolabs
Nov 28, 2006 | Sony Handycam DCR-TRV240E Digital...
Sony Handycam DCR-TRV250E Digital Camcorder Logo
330 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
