Question about EuroTech EWC177 Front Load Washer / Dryer
Eurotech Washer\Dryer EWC177 does not dry
I just replaced Elctro Pump on this machine because it was not draining the water, but now it does not dry. It also happened before the pump replacement, so I know it was not caused by it.
It just does not get hot as it used to.
The warranty just expired, so I am looking into resolving it myself first.
The advice woulld be great.
Thanks.
  • 1,056 Answers
Unplug the power. At the back are several circuit breakers. make sure they all have continuity. They only open in the event of overload, thermal or electrical. After that they are suppose to clickback to normal. If all of them tested ok, check the continuity of the heating element. You may see a break in the nichrome wire coil, thats the heating element.
Posted on Jun 29, 2009
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
Hi, I have a Samsung WA10R3, the draining pump got wet and I had to replace it. Now as the water flows in the machine, the draining pump, pumps the water out again. Aparently it's a control board
ok lourens the problem is straight forward . Im dave phillips Seven hills nsw just retired from my appliance business . What had happened due to to water getting on the the motor winding cause a direct short on the pcb contol board if you had left it to dry out it would have been fine . There are 2 ways of fixing the problem replace with new or get it repaired at module repair service richmond victoria i recommend this company as they have looked after me in the past saving me thousands of dollars. If i can help anybody with there appliance faults email themotownshow@yahoo.com
May 16, 2012 | Washing Machines
I have an Indesit Washer/dryer (WIDL 126 S), and it is dot draining the water. I set in on drain or dry and nothing happens, it just fills with more water.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump needs replaced.
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Washing Machines
Hi, my washer has flooded - not drained at all. it is still spinning as if it is stuck on the wash cycle. The problem is that it isn't draining, or progressing to spin. I stopped it after over an hour...
Hi jeffreysmyth,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | EuroTech EWC177 Front Load Washer / Dryer
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
My machine does not dry properly, very little heat is being delivered to the clothes consequently I am having to hang them to dry. Inez W.
I would suspect that the dryer's heater element is malfunctioning. This would require an engineer visit I fear ;-0(
Sorry,
Good luck, John C
Mar 25, 2011 | EuroTech EWC177 Front Load Washer / Dryer
Dishwasher will not drain. F2 shows up on panel
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Aug 20, 2010 | Asko Dishwashers
Can i connect warm water insted of cold water to this washing machin?
You can use either, just be aware that some soaps foam more in Hot water so try using less
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | EuroTech EWC177 Front Load Washer / Dryer
Power is on, lights are on, put it to a setting and hit start and nothing happens no water(water is on) no spinning and no drying. Have checked all the hoses and cleaned the filter.
I sometimes get this happeing if the door doesn't close and seal. If you can open the door then this is the issue. THe door should seal and won't open when you hit start. Try opening and closing the door tightly
Feb 28, 2010 | EuroTech EWC177 Front Load Washer / Dryer
EuroTech EWC177 Front Load Washer / Dryer Logo
1,069 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
richie46
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
