Question about Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive
My USB was working the other day, now it can't be detected.
I was using it for a while because i was working on study notes. I took it out, everything was fine, but when i put it back in it is not detected anymore and its like this on every computer. Is there some way I can get the stuff off it, or somehow fix it?
My flash drives suddenly died today. XPdetected it as a 0mb device
Posted on Jun 29, 2009
I have tried in vain to get the USB connection on my Westell 6100 to work. Are there some tricks to making this happen? The ethernet connection will work fine, but I cannot get the USB setup to work at...
I suggest that you use ethernet connection instead of the USB connection.
Ethernet is more stable that USB, you less likely to experience dropped connections.
Also take note that you can only use one connection at a time. You CANNOT use Ethernet on one computer, then USB on the other computer.
But if you insist to use the USB connection, you need to install the drivers. Once the usb cable is connected to the modem and computer, you will get a found new hardware wizard screen. Then you will need to insert the CD that came with the adapter to your computer.
If the found new hardware wizard did not appear, check your device manager and look if there is a USB adapter with a question mark or exclamation point. Right click on the USB adapter then click reinstall.
It should detect the drivers from the cd.
Good luck and have a great day!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
CANNOT DETECT THUMB AND USB MOUSE
Some times the USB controller are located in the Chipset, Look at you model of computer and see what you can find to download and install and/or provide a bit more info. computer manu, model, ect
You might try this work around:
disable and re-enable the USB controllers, follow these steps:
  1. Click Start, and then click Run.
    Note If you are running Windows Vista, click
    Start, and then use the Start Search box. I know you are running XP however this may prove useful for all.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. Expand Universal Serial Bus controllers.
    Note You might have to scroll down the list to find this item.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
If the USB port recognizes the device and if you can use the device, you are finished
Good luck...please leave rating, thank you kindly
Apr 29, 2009 | Computers & Internet
External hdd not detected
Formatting a drive means resetting it to manufacturer settings
And deleting everything in there, this solves most of hard
Disk problems, mp3s ipods ect..
if its powering on without being connected to anything do the following.
connect it via usb cable to your pc, or if it’s a hard drive its already connected.
click on start, right click on my computer and go to manage
in the table select, "storage" then "disk management"
in that table find the drive that relates to your mp3 player
if its not there "buy a new mp3 this is faulty" if its there
then right click on it and select "new partition"
you just next next everything and then format it and after
a while it shows "healthy2
unplug it, plug it back on and that's it your drive is fully working
now move what ever you want to it just like before.
Mar 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Scanner not detected
first shut down ur pc disconnect the power cable and usb cable from scanner put the power cable of scanner and see if light is coming if itis coming connect the usb cable check in device manager if it is detected also check the adapter voltages and try replacing usb cable if required
Feb 24, 2009 | Lexmark X2250 All-In-One InkJet Printer
How do i remove the back off a sony vaio to replace usb ports? i have took all the screws out but do not want to put to much pressure on as do not want to break it! (Repairing it for a friend)
You cannot easily replace the usb ports as they are soldered as part of the motherboard. If the ports are not working then go as follows and attempt to reset them
I'm going to assume that you're running XP (home or pro). . This is the sequence to use
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Dec 09, 2008 | Sony VAIO PCG-K23 Notebook
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
2. Click Hardware
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Detected before, but not after. Help me please,
Go to device manager and uninstall everything under the USB heading and restart your computer. This should reinstall all the drivers and hopefully reinstall your mouse. You may need to rerun the driver you downloaded for the mouse afterwards.
My next suggestion your be to try the mouse on another computer to make sure it is not defective.
Jan 15, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Doesnt detect in MTP mode
I had this type of problem, excluding Rhapsody, but when the computer was updated, everything fixed. Sorry I couldn't help more. I think we updated Windows Media Player, but I think ours was 10, not 11. Try running auto update.
May 26, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
152 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
