Hobart 24 in. LXIC-5 Built-in Dishwasher
Problem for Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart 24 in. LXIC fails sanitizer tests.
By weevoe on Jun 29, 2009
Hobart 24 in. LXIC fails sanitizer tests. The sanitizer pump is pumping out about 4-5 ml per rinse when I remove the tube at the 90 degree tube fitting. According to specs it should be about 3 ml of 8.5% solution so it seems to be providing more than enough yet the test strips show nothing.
Comments:
Jul 09, 2009
- We found the problem. The tube in the pump was flattened too much so it would pump when the tubing was removed but did not have enough pressure to inject the rinse stream. Replaced the tube & now the sanitizer is actually too high when tested, which is not a problem to correct.
Jul 11, 2009
Best Solution
posted on Aug 13, 2009
Helpful)
paultech8226
Rank: Guru
Rating: 94%, 15 votes
I thought it was designed for domestic bleach at 5.25%, and looking for a solution of 50 ppm of sanitizer and rinse water. Either the elbow is blocked, or the silicone tube in the pump has collapsed. Use rubber gloves and face protection when working on chemical tubing.
Comments:
Sep 16, 2009
- What's changed? By removing the angle fitting it flows. The angle fitting may be blocked.
If you check the data plate on the machine I think you will find it preferrs 5.25% solution. Usually about 6 ml per cycle will give you 50 ppm, asuming your fill flow rate is 20 psi to give you the correct dilution. The sense boards on the back may reject the stronger solutions unless you recalibrate the board. The stronger solution , if too rich will destroy anything rubber in the pump. You may find tiny black spots everywhere, that smudge and don't come off easily. Thats you pump being eaten away.
If the chemical pump pushes fluid and then it creeps back into the bottle, your silicone tube may have collapsed in the pump. Please use hand and face protection when changing these as you will get raw bleach on your skin, and possibly splash in your face as you disconnect the fittings.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" It was a collapsed tube. Thank you for your helpful insight. If you read all my comments added on July 11 you will see your answer verified. " - weevoe
Solution #2
posted on Sep 27, 2009
Not Rated)
kurtmorganec
Rank: Guru
Rating: 91%, 9 votes
bad test strips or bad sanitizer or the tube is cracked before going in the wash tank thats the only 3 reasons for that problem
Was this helpful?
Yes
No
Popular Solutions for Hobart 24 in. LXIC-5 Built-in
Questions and Unsolved Problems for Hobart 24 in. LXIC-5 Built-in
Do you recommend Hobart 24 in. LXIC-5 Built-in Dishwasher?
Answer
Answer
Hi I´m in Mexico, I need the diagram of LX 30 DISHWASHER Hobart.
Answer
The machine shuts off as it is filling. This is a randomly occurring problem. We will use the... (More)
Answer
LX-18 Hobart need 2 detergent pumps. Can I buy these aftermarket or must they come from hobart
Answer
hobart lx18 no power to detergent pump, during the wash cycle there is no power present at the... (More)
Answer
Temperature in our sanitizer only reaches 90-95 degrees instead of 165. What could be the problem ?
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Newport, KY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
