Home | GE | DBSR453EBWW / DBSR453EBCC Electric Dryer | My dryer catches a pie...
GE DBSR453EBWW / DBSR453EBCC Electric Dryer
Problem for GE DBSR453EBWW / DBSR453EBCC Electric Dryer
My dryer catches a piece of clothes in the drum
By marishie0520 on Jun 29, 2009
My dryer catches a piece of clothes in the drum edge and has ruined quite a few clothes, leaving them with black-brown marks. When I look at the drum seating using a mirror I can see that it's not centered. How do I fix that.
Best Solution
posted on Jun 29, 2009
Helpful)
MrQuickFixit
Rank: Guru
Rating: 97%, 102 votes
Hello Friend, This problem is real common in GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for GE DBSR453EBWW / DBSR453EBCC
Questions and Unsolved Problems for GE DBSR453EBWW / DBSR453EBCC
Do you recommend GE DBSR453EBWW / DBSR453EBCC Electric Dryer?
Answer
Answer
drys for a while then heat stops. open door let cool down inside for a while then will heat again... (More)
Answer
when you hold the motor switch in the on positon the the motor seems to work fine, but you release... (More)
Answer
removed 3 ea screws for removale of metal plate inside GE Dryer Model number DBSR453EB2WW in order... (More)
Answer
Took apart, do not remember were the wires go on the Drum outlet I have orange and orange.Does it... (More)
Answer
dryer does not shut off when on the settings other than the timer. easy care and cotton settings... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE DBSR453EBWW / DBSR453EBCC...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
