Question about Whirlpool Washing Machines
WASHER SHUTS OFF AFTER WASH CYCLE BEFORE FIRST SPIN CYCLE, HAVE TO MANUALLY TURN DIAL TO GET IT GOING AGAIN
Your dial is on its way out i had same problem to be honest once the dial goes your pretty much knackered as having this repaired can cost just as much as buying a new machine, depending on model a repair specialist might beable to get a replacement but dont hold your breath
Posted on Jun 29, 2009
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Kenmore HE2 washer will not automatically advance through all the cycles
I had this same /similar problem with my machine and found that the micro-computer board on the top rear near the cover of the machine are very prone to having bad electrical contacts on the board where the wire connectors go. The answer simply was to remove this board and add solder to each and every solder pad that goes to the connectors. The board is not bad (defective) just poor electrical connections.The repairman probably just wiggled the 1 with the issue and it worked for you for months as described! Perhaps you could get away with just disconnecting the electrical connectors and plugging them back in -it could buy you some more time before fixing it permanently with solder!
Good Luck!
Rich Lilja
Mar 05, 2017 | Kenmore HE2 Plus Front Load Washer
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
The washer is stopping after each cycle (wash, rinse and spin). If I manually move the dial to the next cycle it continues until it stops again at the subsequent cycle. Please advise. Thanks
sounds like the teeth on the timer are going. Some washers however do have a "rest" period to allow the transmission to cool down. give the washer a couple of moments before forcing the dial.
Jul 30, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
43 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
