Question about Compaq Keyboard
Keyboard removal How do I remove the keyboard on a compaq presario 1277 for cleaning?
    Problem Solver:
  • 11 Answers
Generally, keyboards are the easiest thing to replace on a laptop except for memory.
Usually, there are either screws on the back that have little keyboard symbols next to them. If that is not the case, then you need to find a way to remove the little panel that is directly above the keyboard as the screws are probably under there.
Just a heads-up, doing any of this will void your warranty if you are still under it.
Posted on Nov 10, 2007
I have a compaq presario and I dropped some pepsi on the keyboard. some of the keys are very sticky and dont work well. is there a way to fix this without buying a new computer
Posted on Jan 26, 2009
My leptop fingerpad doesnot work as enterkey,just lock the fecility,pl. heip me how i correct it
Posted on Apr 11, 2008
How do i dry out a compaq keyboard from coffee?
If you can remove the keyboard,lift it off carefully. With a Q-tip dipped in alcohol, wipe the coffee spots clean. It dries rather quickly. replace keyboard. Should be as good as new. GOOD LUCK
Jul 02, 2012 | HEWLETT-PACKARD HP Compaq Presario...
Tip
How to Install Compaq Laptop Keyboard
Compaq laptop keyboards have a variety of sizes and configurations to fit the design of the laptop itself like smaller laptops or larger laptops with full-size keys. You might now find that the keyboard or keypad exhibits problems such as sticking keys or general unresponsiveness from your owning Compaq Presario laptop because of several years'using. Besides, you have made sure that your old keyboad is clean but it still doesn't work well. Then you have to install a new one. So how to do it? Don't worry, you can DIY your Compaq new keyboard via this guide.
Step1. Exit Windows and turn off your computer.
Step2. Unplug the power cord and modem and network cables.
Step3. Place your laptop on a clean and disconnect the old keyboard. Open your laptop screen as far as you can.
If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
Step4. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Compaq Keyboard in place.
Note: Keep these screws in a safe place.
Step5. Gently tug the Compaq Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Step6. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right.
Step7. Connect the power on your laptop and verify that the new Compaq Keyboard is working.
OK, well done! Compaq keyboards are inexpensive, easy to find and quick to install. Actually, all Compaq Presario laptops have reasonable prices and you don’t have to worry if something breaks down as replacements are easy to find and cheap to buy from Papatek. Papatek Compaq Laptop Keyboard are specifically designed for each Compaq laptop brand and model.
on Aug 31, 2010 | Computers & Internet
How do I remove the LCD cable from my Compaq Presario C700? Which tape do I remove / What do I do?
You have to remove the keyboard. Most laptops have the keyboard screws at the bottom or underside of the pc and right next to the screw hole is a little keyboard picture thing or illustration that tells you that screw is to hold down the keyboard. once the keyboard is removed, you can easily get the LCD screen wires disconnected.
Aug 25, 2011 | Compaq Presario 700 470024-192 Notebook
Where is clock battery in my laptop compaq presario 1246
Remove the touchpad screws on the bottom of the laptop. Lift the touchpad and the keyboard. Remove the flat metal heatpipe above the CPU (3 screws). On the bottom left, just above the HDD you should see a small circuit board held by 3 screws. Remove these, lift the circuit board and there you go, the battery is there.
Dec 14, 2009 | HP (158800-001) for Compaq Presario 1246,...
How do you remove the actuall keyboard on a compaq presario 1200 notebook computer, i have removed all screws and access doors on bottom end, along with the memory etc.
First remove the top plastic strip piece (where the power button is located) and then use a phillips screwdriver and unscrew the screws holding the keyboard in place. Gently pry it out and then remove the ribbon cable that connects the keyboard to the mainboard
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
Nov 04, 2009 | Compaq Presario 1200 Notebook
Keyboard is locked and i am using external keyboard
I have seen this issue before. Normally, I remove the keyboard and give it a thorough air cleaning to remove any debris that is caught behind the keyboard keys. After that, it seems to work just fine. Good luck. -Carlos:
Jun 13, 2009 | HP Compaq Presario C700T
How do I remove and replace keyboard on compaq presario f730us?
Here is Compaq Presario F700 series manual.
Scroll to page 52 for keyboard removal.
Mar 28, 2009 | Compaq Presario F730US PC Notebook
Compaq Presario 2500 (2598us) loose keyboard
You might want to check the keyboard connection. It sounds as if it's not connected or seated properly.
Aug 20, 2008 | Compaq Presario 2598Us Notebook
Laptop keyboard
Try removing he keyboard, clean the connector on both the keyboard and motherboard. Sometimes this connection will work loose or get dirt or corrosion. Make sure that it's seated well, then try it. If this doesn't fix it, I'm afraid it's time for a new keyboard.
Jul 17, 2008 | Compaq Presario M2000 Notebook
Removal of laptop keyboard
Dear ctmom
Please find below the link to download the
HP Pavilion zx5000 Notebook PC, HP Pavilion zv5000 Notebook PC, Compaq Presario R3000 Notebook PC, HP Compaq nx9100 Notebook PC - Maintenance and Service Guide
( http://h10032.www1.hp.com/ctg/Manual/c00212209.pdf )
Removing the keyboard firstly requires the removal of the top plastic strip in order to gain access with the screwdriver to the four screws. To remove it follow the instructions at pages 137 & 138 and you are almost there.
Then on page 139&140 you will find the information to remove the keyboard. It explains all the information very analytically. You are simply unscrewing the four screws on the top side. On the bottom it is simply slided.
TIP: Be careful when you are releasing the keyboard up towards you. The flexi cable that is connected to the motherboard is quite short-fragile and does not have a lot of space to move so go slow until you have released the connector’s tabs and the cable is loose to be removed.
Please remember to remove the battery before you do any work in the laptop.
Mar 17, 2008 | HP Compaq Presario R4000 Notebook
Compaq Keyboard Logo
614 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
