My daughter put a dvd in the cassette side of the Emerson video cassette recorder and dvd cd player. A blinking green cst.in light insued. I read and took out the cd. The light continues to blink. powered down and up with no change. Help
SOURCE: I have recorded from Vhs
Without sounding too pretentious, I would first advise you to use a QUALITY disc for exactly this reason! Don't be afraid to spend a little more on some TDK or Hitachi/Maxell DVDs! **** DVDs will fail as much as 25-40% of the time, making them no bargain at all!!
That being said, I would also inquire as to exactly what methods/products were used in the transfer process. There are several different ways of writing data to the disc (DAO, TAO, etc...), as well as many different video formats (did you select "Make a video CD" from your application? This will only work in digital video disc players, NOT DVD players!). Only a few (if that) will typically work on any given player.
On that note, my advice would first be to copy the data from the disc back onto your PC if possible (if it isn't still there already), or even from the VHS tape again, and take a look at the file name, particularly the extension, of the copied video file(s). If the extension is not .mpg or .mpeg, then it is NOT in DVD format, and converting to the appropriate format would be a necessary part of your transfer process. Also, make sure you are creating a DVD, not a video disc! They are different! Rewrite the data to the disc in the appropriate format on good quality media using the same process as before and you should be good to go!
I hope this helps! If not, please comment with any additional information and I will respond ASAP and we will get things figured out for you. Thanks for your questions!
SOURCE: VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
[email protected]
