Question about Asko W6021 Front Load Washer
Hi it starts by filling, then stops, i have put it to drain, it sort of drains. i did notice the drum does not rotate. please help Chandani
    President:
  • 744 Answers
Hello, The trouble here is going to be one of two problems, either the pump drain is blocked or the pump is bad, the water is not draining off and the sensor is telling the computer there is still water in the machine. If you are confident you can repair this yourself locate the pump some where in the bottom of your washer, usually there is access panel in front bottom. once you have located the pump there should be an access to the pump filter..pull it off clear it out and try a new wash..bear in mind 2 things..turn power off to washer and when opening the filter water will come out..either tilt machine and put pan underneath or have a few old towles handy. You should be good to go...if this does not solve your problem replace the pump. I'm pretty sure cleaning the pump filter out will solve your problem though...Hope this helps...if you have an other questions or concerns please feel free to comment again. Good Luck!
Posted on Jun 29, 2009
Wont drain with a load, but will drain when empty. Have cleaned filter, have run drain cycle with filter open motors works. have filled using start of 32 min cycle, and emptied using drain, at l
sounds like inside the drum a dog waste bag or a small plastic bag for something plastic has melted onto the heating element
this can be removed for checking not easy bit fiddly but at least you can rule it out
ah you think i didnt have plastic in my wash
got kids?? then the soap drawer is the place all dirty things go to get washed
sounds like some plastic flapping about above the drum drain port
Nov 28, 2014 | Candy Washing Machines
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Front load washer starts an stop
Hi Tyron Tutwiler - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Also try to rotate the drum manually (when it is not in use) and see if you notice a bumping sound as well. If you do, then the drum is not balanced and probably the bearing and pulley system behind the drum will need repairing. Other possibilities could be are a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Jan 07, 2013 | Frigidaire Affinity ATF6000F Front Load...
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
Will not spin
Hi- if the water does not drain from the m/c, then it will not spin.Check to see if the pump is working.
Select drain or empty and the water should pump out.
If it does not, then you have a draining problem.
Hope this helps.
Nov 26, 2008 | Washing Machines
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Sep 23, 2008 | Washing Machines
My Roper top loading washing won't stop filling.
It's not necessarily the angle of your drain hose. When it drains as you fill it, it's called a siphon condition. Pull the excess hose out of the stand pipe (drain). Only about 6" should remain inside the pipe. Tie it down with a plastic tie to one of your fill hoses to prevent water pressure from pushing it back out. This should solve your problem.
Nov 10, 2007 | Roper RAB2121KW Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Asko W6021 Front Load Washer Logo
65 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
