Question about Sharp AL-1642CS Copier
Sharp copier AL-1642CS
I am getting an error code H 4. I have tried turning the copier off but still does not work. Copier will not do anything.
  • 1 more comment
  • ESP597 Dec 11, 2007
    There is no paper jammed in the fusing unit. How to get the simulations and code 14?
  • Anonymous Apr 26, 2008
    My copier show H4 and not working.
  • Anonymous May 23, 2008
    I have four Sharp copiers, got the same problem 4H and they don't work, still new though. The latest copier Sharp that I bought is spelling toner in the copy paper. What's the problem on this? Soon to give up on Sharp copier.
Here is what worked for me.
You need to alternate pressing the clear button then one of the auto buttons until the display lights turn off.
First press the clear button (red letter “C” on the unit) then the auto button. (below the word auto there are 3 buttons. Press the one on the far left that has no other markings on it. This will only take 2 or 3 times back and forth.
When the display is blank enter the number 14 (like you were making 14 copies of something) then press the Green (start?) button. Let the copier warm up about 30 seconds and try making a copy.
It worked for me. Still having trouble call Sharp USA 630-378-3590 or Canada 905-568-7140. They were quick and helpful
Posted on May 27, 2008
Esta solución no fue muy clara para mi y creo que es muy inapropiada
Posted on Apr 30, 2008
    Sniper:
  • 54 Answers
H4-00 is a fuser code. Check to make sure no paper is jammed in fuser (the hot section, on top inside the right side door). Code means low temprature in fusing unit. You can try resetting the code by entering the simulations and using code 14 to reset. If this does not fix it you need to replace the fusing unit.
Posted on Dec 03, 2007
  • Bryan Luther Dec 12, 2007
    To enter simulations, push the following buttons in order. P Interupt, clear, interupt. When you enter these quickly, the display should go blank. Now enter 14 and push the Copy button (the one you normally use to start copying). The machine should reboot, and your code may not return. If it does, then you need to replace the fuser.
    Don't forget to rate your answers please.
This is a fuser problem. Replace the fuser and clear the H4 code and life should be good!
Posted on Nov 07, 2007
We have a Sharp AL-1642CS Copier machine. That currently isn't working. What does a CH code mean?
CH code = Toner Cartridge is missing or not installed properly. In rare cases it is a defective toner cartridge. Also double check the right side and front doors proper closure.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1642CS Copier
Had a paper out code, so fill the try and try to start the copier and all I get is a "L" then back to a "1"
You can find the solution to this error by viewing my tip for this problem. Just search for Sharp AL series L1 on this site
Mar 23, 2010 | Sharp AL-1642CS Copier
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Error code h4 on sharp al-1642cs
I have a solution for this posted in the tips section. Just search for Sharp AL H4
Jan 16, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Sharp copier al-1642cs
This error is caused when the scanner glass is in the locked position. Make sure it is unlocked underneath the scanner on the left side.
If you look into the scanner is the ribbon cable tangled up or frayed?
Apr 16, 2008 | Sharp AL-1641CS Laser Digital Copier
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
1,349 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
