Question about Microsoft Office Excel 2003 for PC
Excel radom selection formula not working
In a coloumn i have entered starting from cell a10 to a36, and in a4,i have entered starting no as 1 end in a5, ending no as 245. i have entered the following formula to select the random no in b10 =IF(ISTEXT(A10),"",RANDBETWEEN(C$4,C$5)) but the result is not coming?
  • 66 Answers
What are the values of cells C4 and C5? Should the function above be "...RANDBETWEEN(A$4,A$5)" ?
Posted on Aug 28, 2009
IS THERE A FORMULA IN EXCEL THAT WILL HIGHLIGHT CELLS THAT MATCH A NUMERICAL INVENTORY LIST?
One way would be to create a colunn C and use the formula: =COUNTIF(B$2:B$200,A2) in cell C2. Then copy the formula down to C200. (assuming you have 200 entries in B...). This will put a "1" next to every number in Column A that has a match in column B. Then you could put a conditional formula in column A that will highlight the cell if the value in column C is equal to 1. Alternatively you could also simply filter for 1's in column C and then manually highlight the cells that show up in A!
Sep 16, 2014 | Microsoft Excel for PC
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
Excel Real-Time
  1. open ur spreadsheet from your files that you want to insert a dynamic date and time
  2. select the cell into which you want to insert the dynamic date and time.
  3. Type "=now()" (ignore quotation marks) into the selected cell.
  4. Press the "Enter" key on your keyboard to enter the formula into the selected cell. You will now see the current date and time appear in the cell you typed the formula into. (Date and time will update every time the "Enter" key is pressed )
Feb 17, 2009 | Microsoft Computers & Internet
Excel
Step1. Start Microsoft Excelmag-glass_10x10.gif and open the file you want to change. Step2. Double-click on the cell where you want the total to appear. Step3. Press the = key on the keyboard. This tells Excel that you are entering a formula into the cell. Step4. Enter the formula, then press Enter. Follow the steps below for an example. Step5. Enter an opening parenthesis character: (. Step6. Enter a cell name. For example: =(E2. Step7. Press the + key. Step8. Enter another cell name and a closing parenthesis character: ). For example: =(E2+E3). Step9. Enter a minus sign and a third cell name. For example: =(E2+E3)-E4. Step10. Press the Enter key to accept the formula. The cell will display the sum of the first two cells minus the third cell. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Tips & Warnings
  • Formulas are just equations. Instead of adding or subtracting numbers you are adding and subtracting the contents of a cell.
  • Excel includes a number of predefined functions to use as well. You can combine the predefined functions into your own formula. (See "How to Use Provided Excel Formulas.")
I hope it helps!!!
Dec 03, 2008 | Microsoft Office Professional 2007 Full...
Populate a cell based on a specific criteria in Excel
[formula in the new Category Column]
=RIGHT(A1,LEN(A1)-SEARCH(" ",A1,LEN(A1)-11))
Where A1 is the cell that stores the Business names.
May 20, 2008 | Microsoft Excel for PC
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
Ms excel fomulas
dear monalinda you have to enter formula in formula bar with = sign and select the coloumn & rows
Sep 24, 2007 | Microsoft Office Standard for PC
Excel formula
Relative cell reference is address of cell , when copied from one cell to another gets changed automatically.
e.g. Put formula in cell c5 as A5+1 when you copy this from c5 to c6 the address of A5 will automatically changed to A6.
Absolute Cell Reference
As above now put formula in cell C5 as $A$5+1 ,now copy this formula from C5 to C6 if you this formula youwill find cell Address of A5 does not changed.
Mixed Cell Reference:
If we put Dollar ($) sign before Alphabetic cell address i.e.$c5 then even if you copy this formula in any cell , coloumn (c)  will remains constant.
Similarly if we put Dollar ($) sign before Numeric cell address i.e.c$5  then you copy this formula in any cell row address of the cell remains same.(5).
Pl elobarate on remaining two points 'Specific order of formulas ' and 'advance formulas,
Sep 15, 2007 | Microsoft Office Standard for PC
Microsoft Office Excel 2003 for PC Logo
83 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
