My yamaha dv-s5650 is only playing in black & white!
  • 4 more comments
  • robnfa Jun 29, 2009
    It's not the video IC on the TV as i plugged in my portable dvd player and it's in colour, so it's something to do with the yamaha dvd player settings!
    that didn't work
    that did not work, still looking for a solution!
    restoring factory defaults did not work. I tried that already
    I will not accept as the problem is not solved.
    And now I have lost my programming for multi region dvd playback, so I'm not a happy camper.
    Sniper:
  • 111 Answers
UR AV CABLE MAY BE BROKEN
aS IT CONTAINS COLORS "RBG" .
OR the NTSC to PAL conversion exhibits frequent video sync problems The image will slightly CHANGE ITS COLORS
Posted on Jun 29, 2009
    President:
  • 828 Answers
Look at the manual, you can set their into Multi-view setting, maybe it appears only a PAL viewing.
    Brigadier General:
  • 8,619 Answers
Hi
Please make sure the NTSC/PAL setting at this unit matches the video signal of your television. Press 3 or 4 to select PAL, NTSC or AUTO. See NTSC/PAL Settings:
– Black level shift (NTSC output only)
Select On for adapting the color dynamics to obtain richer contrasts.
– Monitor Type
Allows you to select the type of display device that is connected to this unit. In each device, a set of predefined Color settings is available or choose Personal that allows you to select the color settings according to your preference.
– Video shift
Use this setting to personalize the position of the picture on your TV by scrolling it to the left or right.
– Color settings (Smart Color)
You can select one of four predefined sets of color settings and one set (Personal) which you can define yourself. You can also switch the settings by accessing the in the menu bar.
When Personal is selected, it allows you to fine-tune saturation, brightness and contrast.
Use 3 or 4 to adjust the values of these parameters.
AUTO can only be selected when using a TV that has both the NTSC and PAL systems.
Slight picture distortions may occur due to this conversion. This is normal. Thus, the AUTO format is most suitable for the best picture quality.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jun 29, 2009
    If it is still not resolved then you need to reset the unit by pressing the stop and next button for 10seconds.
    Thanks
    Rylee
    President:
  • 1,383 Answers
I have a Yamaha DV-S5550 and recently did the same thing. Our players may have the same menu system. Give this a try. Turn the power to the dvd player on. Using the remote, follow this key sequence exactly. Press the onscreen button. Press the down directional key once. Press the right directional key once. Press the down directional key six times. Press the right directional key once. Press the down directional key once. Press the left directional key once. Press the onscreen button. Your player should now be set to NTSC output. Good luck!
  • kishor
    kishor Jun 29, 2009
    okay reset all settings to factory defaults then check .
    Genius:
  • 1,269 Answers
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
My onkyo dv-cp701 only plays dvds in black and white?
change the format of output from ntsc to pal or pal to ntsc
Apr 02, 2011 | Onkyo DV-CP701 Multi-disc DVD Player
My camcorder has stopped recording in colour and will only record in black and white? Play back is black and white too.
set your cameras settings to COLOR, someone has changed your settings in video display and recording settings
Sep 17, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
Region code locked
my v.zon plays but cannot see picture clear it is a portable dvd player.
Apr 19, 2008 | Yamaha DV-C6660 Multi-disc DVD Player
Yamaha dv-s5650
Feb 24, 2008 | Yamaha DV-S5650 DVD Player
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
