Question about Samsung CXE1331 13 in. Combo
Samsung cxe-1331 with no remote
I have a samsung cxe 1331 tv\vcr combo (not sure of screen size) with no remote i have tryed to use my direct tv remote to find the code with no luck all i want to do is get it in to video mode for games any help with this issue will be great
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
  • 3422 Answers
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
Posted on Oct 09, 2008
  • 408 Answers
SOURCE: i have a RCA rcu300w universal remote what is code
http://support.radioshack.com/support_video/doc67/67859.pdf
That is the manual with all the code listings you will need.
Posted on Feb 20, 2010
SOURCE: need samsung CxJ1952 universal remote code
Can anyone pls help me with the universal code of Samsung CXJ1952.
Posted on Sep 26, 2010
gopakumarg43
  • 75424 Answers
SOURCE: I need a code for our Samsung TV/VCR using a
Hello
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR.
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
0358_0942
Posted on Nov 22, 2010
I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
I hope this helps.
Oct 03, 2011 | One For All URC-3021 Remote Control
How do i find the code for my samsung TV/video model T1-14N3, to makemt universal remote work?
Hello
Four digit universal remote codes for Samsung TV/DVD combo are:
0455 0963
TV/VCR combo are:
0358 0942 0942
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Sep 30, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
Need the remote code to my Samsung TV. My model is: TVN5054CA
Hello
Three digit universal remote code for Samsung Tv are:
002 012 102 103 112 212 502 512 818 914
Four digit remote code for Samsung TV/VCR/DVD combo is
0942
DVD/VCR cobo are:-
0455 0963
TV/DVD combo is
0942
Direct Code Entry
OK.
Dec 28, 2010 | Samsung CXD1342 13 in. Combo
I have a LG TV Universal remote and I'm trying to program it to a Samsung DVD/VCR Combo and I'm not able to do this. The remote model # is MKJ32022834.
TV manual has instruction and codes, or Check www.remotecentral.com for the manual and codes. Some combo setups won't work with alot of the universal remotes tha come with TV's. Also Try aftermarket universal remote.
Mar 14, 2010 | Directed 434MHZ Remote Control
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual.
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Samsung tv vcr combo
according to the info I have on that set theres a front panel control key theres also a lcd display?? as I see the picture you may have locked the set with this control key?? if this dosent work go online and look up samsung LTP179DW remote controls or contact samsung directly at www.samsung.com and go to customer assistance. Hope this helps ya!
Apr 02, 2006 | Samsung LTP179DW 17 in. TV/DVD Combo
Samsung CXE1331 13 in. Combo Logo
237 people viewed this question
Jerry Greenberg
Jerry Greenberg
