Question about Kenmore Washing Machines
Spin cycle not working - Kenmore Washing Machines
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 11, 2010
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
The Spin Cycle does not work
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Jan 16, 2013 | Washing Machines
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
