Question about Gateway Computers & Internet
It starts to POST, then it stops about 3/4 the way through
    Genius:
  • 1,847 Answers
Reinstall the OS.
thanks
K
Posted on Jun 29, 2009
The pump stops and starts intermittent
Ken, RE POST with more info, pump for what, year, make ,model # and complete question.
Feb 19, 2016 | Cars & Trucks
My 1999 rodeo isuzu rebs up loud (dleing up) and jerks when stopping . Idling up high when starting is it my idle air control system?
i changed mine took to 3 shops last one said computer i would take pos cable for 30 sec turn on to acc and tap post 3 times if it helps
Jun 27, 2014 | 1999 Isuzu Rodeo
I start the engine, and can not continue runing in low speed, then the engine stop runing
a friend told me to take the pos cable off with the key turned on acc wait 30 sec then touch post sounded crazy tried it worked for me good luck cable to hot post 3 times
Mar 15, 2014 | 1999 Isuzu Rodeo
2002 suzuki grand vitara not starting when hot have to leave it 15 minutes before it will start again
what engine, 2L I-4 or 2.5L V6? post engine, for best answers
or Post VIN, or open hood (USA) look up see EPA vacuum sticker. that tells you the engine type.
ever do the 60,000 mile tune ups, 120k, 180k,etc?
1: after the tune up.
Ill assume it cranks robustly but does not start hot.
2: does using the op guide recommended WOT method start car
when dead? ( press right foot to floor, crank , bingo it starts)
If true that means it was flooded. post back if true.
3: if it dont start WOT (wide open throttle)
that means, its lost spark or lost fueling.
so check for spark using a new , gapped proper test spark plug.
got spark? no , post bad, Ive no spark hot.
4: gots spark but will not start. so use test fuel.
starts now>
A: for only 3 seconds, it runs but then stops. each attempt.
yes, then you have fuel pump issues, (no didnt say bad pump!!!)
no, engine issues. hot motor , has lost compression?
yes> post compression on all cylinders warm to hot. WOT.
or watch scotty do it. (oldest story on cars, ever, no start , 100 years)
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Nov 25, 2013 | Suzuki Grand Vitara Cars & Trucks
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Error 0175: Bad CRC1, stop post task
ERROR
0175: BAD CRC1, STOP POST TASK.
Firstly, this error is generated due to a couple of different reasons. First, there may actually be a problem with the power circuitry and the CRC function is actually doing it's job reporting the error. There are several tests you can perform to tell if this is the case with your system.
Secondly, this bad CRC error can be generated by sudden power loss to the system, especially if the system loses power during boot up or POST process. Both mean that there could be a problem with the motherboard and it needs replacing.
Try the steps below to determine what is wrong.
1) Start the system and watch the status lights in the LCD hinge or near the power button. They should flash once (some models twice) before the system shows a display. If they flash 3 times or more, you have a power problem.
2) Start the system and allow it to reach the CRC "stop post task" error message. Let it sit at this error for several hours. The system should sit at this error for ever or until user intervention occurs.
3) Some things to watch for while the system is sitting at the CRC error and running for several hours would be: Screen going black, System rebooting, System powering off, ect.. ect.. ANY activity by the system is a warning that power problems exist in the system.
4) Try restarting the system several times consecutively, shut the system down by holding the power button for 5 seconds, then restart keeping an eye on the status lights for any additional flickers.
All the above tests should be done with AC power applied and battery installed. Also ALL drives installed.
Regards.
Jan 19, 2011 | IBM ThinkPad T23 2647 Notebook
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Washer says DC and stops on rinse cycle
DC= Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Sep 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Starter keeps turning even when key is turned off
Curious, do you have an autostart installed? I had that happen that the Autostart shorted and just kept telling my starter to continue cranking
Aug 11, 2009 | 2000 Jeep Cherokee
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Computers & Internet Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
