Question about Dell Inspiron 600M Notebook
Dell 600m Computer won't power with adaptor connected
Battery was low went to charge by pluging in adaptor screen came up with message A/C adaptor not found...battery then died before being able to read rest of message. Caught a glimps of it saying something about internal card activated and then internal card switching off to save battery although adaptor was still plugged in and should have been charging.
Adaptor works as I tried it on another Dell laptop (640M), Can't check battery as different model notebook
  • ianbb458 Jun 29, 2009
    Thanks Guess gotta take it to the tech and hope he can get amotherboard here.
  • 61 Answers
Bad motherboard, unfortunately. Seen it before as a Dell tech.
Posted on Jun 29, 2009
Dell latitude d520 starts with battery but not with ac adaptor
It could be a bad adapter, a short that drags everything down when plugged in.. could be a short inside the computer doing the same thing.
Borrow an adapter to see if you get the same result, if a friend or shop will help you with that.
A digital VOM could tell you if the right voltage is being put out by the adapter. Read on it, if it's supposed to be DC voltage and you get AC, the adapter is bad.
Oct 02, 2017 | Dell Latitude D520 Notebook
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
I have a new dell inspiron m5030 but when i turn it on this day i got a message "Warning:The system unable to charge the battery. please help me with my problem. thank you
There is a BIOS update available from Dell that is supposed to cure this problem.
Bios updates can be found @:
http://search.dell.com/results.aspx?s=dhs&c=us&l=en&cs=19&k=Dell+Inspiron+M5030&cat=sup&x=0&y=0
I solved the problem by using up my battery until the the screen would black out. Afterwards, I rebooted it (again without using AC adaptor) and the system warned me of low battery and to press F1. After pressing F1 I plugged the adaptor back and tried rebooting. The problem was solved
Jun 13, 2011 | Dell Inspiron M5030 Laptop
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Plug in ac adaptor to Dell inspiron 600m and does
Sounds like you have a broken DC Power jack. This is where the small socket where you attach the AC adaptor breaks loose from the motherboard , resulting in the laptop not charging properly or at all . If you have to wiggle the power jack to get a connection then this is definately theproblem.
Most computer reapir shops can do this for about $100. Or if your handy with a soldering iron and dont mind disassembling the laptop , you can always buy a new DC jack for your make and model off ebay and try to solder it yourself!
If you found this post helpful , please rate my post
Regards
1234s282
Apr 17, 2010 | Dell Inspiron™ 600M PC Notebook
Dell 600m laptop fell off table. Pwr connector ended up bent. Unit will not power up now., even from fully charged battery. Opened up unit and made sure there is no damage to motherboard at power jack. ...
Hello there...
As far as I know there is no power fuse on the motherboard.
But can you try this: Power on the laptop without the battery equipped, only use the AC power adaptor.
Hope this helps....:D
Apr 14, 2010 | Dell (04U621) for Latitude D600, Inspiron...
My battery got low and the low battery message
sometimes a very low battery will cause screen-freeze...once fully charged, remove the back cover and pull the battery out for 30 seconds and replace the batt and cover...the phone should power on.
Mar 29, 2010 | Cell Phones
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Won't power up. Battery is charging though.. Help! How hard is it to replace the power supply in a Dell laptop?
There shouldn't be any wait time once you plug the laptop in you should be able to boot the machine. Reliable ac adaptors are found at many good tech places of course to be 100% certain could shop from Dell.com
Jan 16, 2010 | Dell Inspiron 600M Notebook
Dell Inspiron 600M Notebook Logo
205 people viewed this question
Alun Cox
