Question about Teledyne Laars Pool & Spa
I have a Teledyne Laars Model EPC-II pool heater; the (2) stainless steel water circulating tubes are leaking at the PVC unions. These PVC fittings have a ring that slides over the SS tubes flange and compress to a PVC union with an "O-Ring" making the water tight connection to the SS flange; The PVC threaded sleeve is cracked and I need to replace either the PVC sleeve that screws over the SS pipe flange or buy an new PVC union; I can't seem to locate this PVC union; any suggestions?
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 718 Answers
SOURCE: Where can I download an instruction manual for
You can download some information from;
http://www.manatron.net/Pdf's/JANDY%20MANUALS/heaters.pdf
This will give a parts list, applications and diagram.
Posted on Mar 27, 2009
john224
  • 1378 Answers
SOURCE: what type of pipe is needed on the inflow of the teledyne laars?
Most pool stores carry a set of two pipes used for older heaters. They are about 17" long, stainless steel, and bend 90 degrees about 8" from one end. They are usually refered to as heat sinks. The fact that the old one has pin holes in it would lead me to believe using PVC would be a bad idea.
Posted on Jun 14, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
Teledyne laars leaks excessive water. is it dangerous?
if not leaking over flame ok to use but you need new heat exchange
Aug 03, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Where's the thermocouple teledyne laars xe pool heater
follow the silver tube from the gas valve follow down under
Nov 06, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Leak in heater after winter freeze
Yes you can just be sure to leave enough room to plumb it back in when your ready.
May 01, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
Swimming pool heater
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
What type of pipe is needed on the inflow of the teledyne laars?
Jun 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
314 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
