I have a 2wire router connected to a pc via Ethernet. I reset it and now my Internet light below the dsl light is red. When I try to connect it says limited or no connectivity. And ie says this page cannot be displayed... Please help I don't know what to do!
    Genius:
  • 1,689 Answers
Kenny,
upon resetting your 2-wire router, you have lost the settings in its firmware. to have this issue resolved please contact your ISP and have the settings as well as the authentications on your 2-wire.
regards,
voodoo
Posted on Jun 29, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
2wire Modem blinking red dsl light problems. Tech came out and check out phone line, tried his own Ethernet router and still got the blinking red under DSL. Tech order for a port change on att company...
if the speed was upgraded to ADSL 2 you need ADSL filters that match this. Check the model number of the ADSL filters and check the type of DSL is compatible with the Speed change.
Apr 11, 2017 | 2wire (1000-000057-000) Modem
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
My router flashes DSL, no light on the internet, ethernet and wireless flash together, and power light on. no wired or wireless internet. solution? the afternoon it happened, a lightning storm came thru...
Hey danielbartle,
Since a lighting storm came through there is a good chance your router has been fried.
I would first direct connect via your modem to see if you get a internet connection and rule out your modem as a problem. If that doesn't work I would try another ethernet cord to rule out your cord is a problem. If you get no connection directly through your modem, I would contact your ISP with your problem.
If you get a connection I would then reset the router by unplugging and waiting 30 seconds and plugging it back in.
If still nto succesful I would reset your router to defualt settings by a small button you will find on back.
If none of these work I would head to your local computer shop and pick up a new router.
Thanks for using Fixya!
Jul 22, 2010 | 2wire (1000-400108-001) Router
2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Connection to my computer of hp photosmart c6300 via belkin adsl2router
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Computers & Internet Logo
David Payne
David Payne
